Old 05-26-2014, 09:56 PM   #1
jammer3096
help with universal joint depth on Chinese steering column
does anyone know the correct depth the universal joint should slide onto the DD shaft on steering column?
jammer3096 is offline   Reply With Quote
Old 05-26-2014, 09:58 PM   #2
jammer3096
Re: help with universal joint depth on Chinese steering column
also does anyone know how to tighten up the slop in the steering column of the cheap Chinese steering columns from CPP?
Old 05-26-2014, 10:18 PM   #3
csfields
csfields's Avatar
I just got one and installed from CPP. I was actually quite happy with it. The steering column was very tight. You can tighten up some slop in the gear box. It's the cent screw on top. I also used a stock intermediate shaft from a donor truck. I would suggest that first.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 05-27-2014, 08:06 AM   #4
jammer3096
does it have splines or DD at the end of steering column?
Old 05-27-2014, 09:44 AM   #5
csfields
csfields's Avatar
The original intermediate shaft had splines top and bottom. Slides right over the the CPP colum with splines.
Thanks,
Casey
Old 05-27-2014, 10:04 AM   #6
jammer3096
Do u have any play in column and do u know what the warranty is on them?
Old 05-27-2014, 10:17 AM   #7
Tylerz181500
anyone know if the jeep xj shafts work on these trucks as well? i know they work with 82-92 camaros as well as 88-96 chevy trucks as well. that or the astro van shafts that have both u joints eliinating the rag joint
Tylerz181500 is offline   Reply With Quote
Old 05-27-2014, 10:34 AM   #8
csfields
csfields's Avatar
Mine seems to be very tight, not sure what the warranty was.
Thanks,
Casey
Old 05-27-2014, 09:51 PM   #9
jammer3096
I'm trying to figure out if my new steering column is junk or not does. Where the splines are on the shaft is it normal to beable to wiggle up and down?
