Old 05-26-2014, 11:04 PM   #1
70chev383
70chev383's Avatar
disc brakes
I was wondering if it would be possible to use 1 ton dully rotors on 71 1/2 spindles?
thanks
70chev383 is offline   Reply With Quote
Old 05-26-2014, 11:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: disc brakes
no.
Keith
Convert to disc brakes.
Old 05-26-2014, 11:38 PM   #3
70chev383
70chev383's Avatar
Re: disc brakes
whats the difference in them?
Old 05-27-2014, 12:09 AM   #4
mgchevyparts
mgchevyparts's Avatar
Re: disc brakes
Nothings the same. Just buy the correct rotors, readily available.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 05-27-2014, 12:16 AM   #5
lolife99
lolife99's Avatar
Re: disc brakes
Dually rotor needs the correct year C30 spindle.
The C30 spindle needs a different upper and lower balljoint, a different outer tie rod and a different lower control arm with a larger hole to accept the c20/c30 balljoint.
Different bearings.
Different caliper.
Everything.
Keith
