05-27-2014, 12:26 AM | #1 |
Rusty Nuts
I made a 400.00 mistake
I bought a rear axle but i did not measure the leaf spring purches cause i thought if it was comming out of a leaf spring truck it would fit. (NOT).
But now I need to know if 1971 and 1972 gmc and Chevy trucks 2 wheel and 4 wheel drive leaf spring rearends are the same width. Or is there a chart to show what trucks will interchange and match my 72 4 wheel drive C10 leafspring pearches. I have searched but couldn't find anything. Now I have a rearend that not going to fit easily like I wanted. thanks for any help.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
05-27-2014, 05:05 PM | #2 |
SWB 4x4 Collector
Re: I made a 400.00 mistake
Just cut off the spring perches and buy some new ones and weld on. Not too hard if I were to save $400. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-27-2014, 09:25 PM | #3 |
What he said.
But for future reference, 67-72 2x4 trucks and 1/2 and 3/4 ton trucks both 2 and 4WD '73-'87 have 42.5" spring centers. 67-72 4x4 trucks and '73-91 30 series trucks have 40.5" spring centers. Shock mounts are in the wrong place for the early truck on the later housings. There are no straight up bolt in housings for a 67-72 except from a 67-72.
05-27-2014, 11:19 PM | #4 |
Rusty Nuts
Thanks guys for the info, this rearend came out of a 70 or 71 gmc but I guess gmc 's are different.
05-28-2014, 05:13 AM | #5 |
Which axle did you buy?You can get a swap kit online that comes with spring perches shock mounts u bolts the whole works.Just weld it on and be good to go.
05-28-2014, 09:34 AM | #6 |
Rusty Nuts
Well its a 12 bolt 6 lug and the guy also told me it was a 3.08 but its a 3.73 so now i an really not going to need it. I am trying to get hold of the guy and work things out.
06-16-2014, 10:56 AM | #7 |
If it is really a 3.73, it is highly sought after.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-16-2014, 11:19 AM | #8 |
Vintage 4x4s
No, they are the same. It sounds like yours came from a 2x4 or newer 4x4 per the info Mike C posted above. Given that, spare 4x4 67 to 72 axles may take a little while to find. Also, i think the hub face to hub face lenght increased sometime in 1970 so look for a 71 to 72 or check width to be safe. I know this is true for 2x4s but not sure on K10,s.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
06-16-2014, 03:00 PM | #9 |
Rusty Nuts
i just rebuilt the one that was under my truck, all better now.
