Old 05-27-2014, 01:14 AM   #1
chevy1970c10
Installing body mounts?
I have new body mount bushings to install and im wondering whats exactly i would need to do to install front and rear cab bushings without removing entire cab?
chevy1970c10 is offline   Reply With Quote
Old 05-27-2014, 01:20 AM   #2
leftybass209
leftybass209's Avatar
Re: Installing body mounts?
Loosen but don't remove 3 of the 4. Jack up one corner at a time and slide out the old mount and replace. Repeat for the others and you are done.
leftybass209 is offline   Reply With Quote
Old 05-27-2014, 02:00 AM   #3
chevy1970c10
Ok seems easy enough! thanks!
Old 05-27-2014, 02:12 AM   #4
swamp rat
swamp rat's Avatar
I loosened all of them first, including the radiator support as there are rubber mounts there as well, then i jacked up one side first using 2 jacks, one on the rad support and the other for the cab using a block to spread the weight load.
Keep an eye on your brake lines and shift linkages ect on the driver side.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
