Old 05-27-2014, 11:59 AM   #1
72step
72step's Avatar
Where to start with cab patch repair?
I am working on a 65 C10 and I've finally finished the metal work on all four fenders. Now I'm ready to move on to the cab which will consist of a driver rocker and cab corner, driver lower kick panel, two small sections of 4"x4" outer floor and the very outer part of the cab supports.
Now where do I start? Cab supports first then move on to the small piece of floor and kick panel then save the rocker and cab corner for last or vice versa? I'm still on the fence about removing the cab. The cab support rust is only the last 2-3" near the inner rocker. Thanks for any advice!
72step is offline   Reply With Quote
Old 05-27-2014, 02:57 PM   #2
morethanstock66
morethanstock66's Avatar
Re: Where to start with cab patch repair?
I'm actually doing a very similar repair on my 66 now- all except cab corners. The easiest way to do it is start cutting from the outside and work inward, then start repairing inside and work outward. I'm no expert on cab corners though.. Got any pics?
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 05-27-2014, 03:09 PM   #3
padresag
look under the section. you will find ample information.
ron
padresag is offline   Reply With Quote
