Old 05-27-2014, 03:05 PM   #1
westpoint
first build....82 silverado c10
Hi guys. Just picked up a c10 from miami. Removed front end and bed. At sand blasters getting ready for por 15. Any advice is welcome. This is my first build. Thanks Joe.
westpoint is offline   Reply With Quote
Old 05-27-2014, 04:03 PM   #2
rusty76
rusty76's Avatar
Re: first build....82 silverado c10
Looks like a good start! So what are your plans?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-27-2014, 06:05 PM   #3
westpoint
Thanks Rusty. I have a few ideas but am very open to suggestions. First I am going to get as much of the frame coated with por 15. Then I will start from the rear and work my way up to the costly parts. I am a fabricator welder by trade and build and race ihra bracket cars with my family. Tomm I will be my truck back from sand blaster. Then coat or 15. Then im go I to change axle wheel bearings, replace u joints in drive shaft. Im also going to replace the rear brake lines. I have a lmc catalog I just got. They seem pretty cheap for tell most part. Is there a cheaper place to buy parts?
Old 05-27-2014, 06:45 PM   #4
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Welcome! Looks like you are starting with a fairly straight truck. Be careful with the sand blasting. If they aren't used to doing sheet metal or get a little too close overheating the metal will cause warping. I saw a '69 Camaro once that was sandblasted by someone who didn't know what they were doing and every body panel on the car was so wavy they all had to be replaced. That being said, starting with freshly cleaned metal is awesome.
Just take your time and enjoy the journey. Restoring these old trucks can be addicting!
Edit: Meant to add: Make sure you get primer meant for bare metal. Needs to be self etching to adhere correctly.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 05-27-2014, 07:00 PM   #5
westpoint
Mike
Thanks Mike. I told them not to do the panels just the frame and heavy metal. The por 15 is a product tou can brush right on bare metal as long as you prep it first with two other products....heres a link if someone here is not familiar with it...http://www.por15.com/
Old 05-27-2014, 07:04 PM   #6
Mr.Chevy4x4
Ok, I gotcha. I was thinking you were getting the sheet metal done also. Por-15 is good stuff and tough as nails. Just don't use the regular por-15 on areas that will be exposed to direct sunlight all of the time. UV rays break it down pretty fast and will make it chalky looking.
Old 05-27-2014, 07:10 PM   #7
westpoint
I have a question....once I get to lowering my truck how low do go for a daily driver? I want to be able to pull my boat so the truck needs to be functional plus i dont want to be scared of speed bumps and train tracks. I was thinking 2" in front and 3" in back for a even look. What do you ghys think?
Old 05-27-2014, 07:11 PM   #8
westpoint
Good tip on the uv exposure. Thanks ill keep that in mind.
Old 05-27-2014, 07:45 PM   #9
Mr.Chevy4x4
2/3 is good for a daily driver, especially one that will still have some towing duties. I lowered my last build 4.5/5.5, and it was still fine for daily driving but it never towed anything. If your boat is heavy you might want to consider some air bags.
Looking forward to following along on your build.
Here are before and after lowering:
Mike
Old 05-27-2014, 08:28 PM   #10
westpoint
Mike
Cool. Ill run with the 2-3. If I am start in in the rear is there anything I need as per performance while im doing u joints brake likes and seals and bearings? This will be my daily driver by if I want to lay rubber I need that option.
Old 05-29-2014, 08:37 AM   #11
westpoint
POR 15 first coat....
Old 05-29-2014, 08:53 AM   #12
Mr.Chevy4x4
Looking good!
Old 05-29-2014, 09:12 PM   #13
westpoint
Ok well today I took out the rug dash and panel with old ass radio. Ill post pics soon. I saw that my vent windows are in back shape. The metal hugging the glass is rusted beyond repair at the bottom. Where can I find parts?
Old 05-30-2014, 03:01 PM   #14
westpoint
Did a little interior demo since it was wet yesterday.
