05-27-2014, 03:10 PM | #1 |
The Older Generation
Making Keys For The 55-59 Chevy Trucks
This "How To" is for the guys & gals that have a door handle with a lock for their 1955-1959 Chevy truck but no key. It is pretty straight forward but I have had a couple of people ask me how to get a key cut for them.. First thing you have to do is remove the handle assembly from your door (if it isn't already out). (picture 1) To remove the lock cylinder assembly push down on the top spring cup and remove the snap ring. (picture 2) Then slide the spring assembly out making sure to keep the parts in order. (picture 3) If you will notice the spring cups are different on each end of the spring. After you have the spring assembly out slide the lock cylinder and shaft out. You don't have to worry too much about this as it will only go back in one way…. On the cast piece just below the chrome cap you should find a code number stamped. (picture 4) A good full service locksmith should be able to cut you a key from that code number that will fit the lock. It should also fit the ignition lock and glove box lock if none of the locks have been changed or replaced. I can't guarantee there will be a code number on every lock, but if there isn't, a full service locksmith can remove the chrome cap and make a key by "reading" the wafers in the cylinder.. If you can't find anyone in your area to cut a key from the code # or by reading the wafers let me know. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-27-2014 at 03:16 PM. |
05-27-2014, 06:22 PM | #2 |
Re: Making Keys For The 55-59 Chevy Trucks
Good info! funny timing! I had dug up the same info (without the nice pics) and just stopped by an old school locksmith today to have him cut me a key. fingers crossed it will work in the ignition!!
Keys for this truck were lost 20+ years ago- previous owner had rigged up a switch under the dash spliced into the ignition wires to bypass it.
_____________________________________ Ben R. 1953 Chevy 3100 Classic Seat Restorations -Preventing me from working on my own projects since 2009! |
05-27-2014, 08:25 PM | #3 |
GREAT INFO!
Thanks so much for posting this. It's great stuff that very few people know much about anymore and you are helping a lot of guys. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-28-2014, 01:06 AM | #4 |
My key worked!!!!
05-28-2014, 01:55 AM | #5 |
Nice, professional how-to, LockDoc!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
05-28-2014, 07:10 AM | #6 |
I had a friend with a ring of 66 master keys that fit a number of old GM vehicles. The ring came in a box of stuff from an old GM dealership. Match up the key then get a copy.
Here in NH it's considered a major violation to be in possession of a master key. |
05-28-2014, 10:32 PM | #7 | |||
Thanks Bob. Quote:
LockDoc
05-29-2014, 12:54 AM | #8 |
In the 70's I worked at a gas station/ garage near the airport. We got a lot of lock out calls from people coming back to town. The boss had a metal box with a bunch of master keys for all makes, in two years never recall one not working. I have kept copies of all the car keys I ever had and some opened other rigs. My dad has two old coffee cans full of them too. including a ring of old skeleton house and furniture keys.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-29-2014, 09:14 AM | #9 |
That explains why my '55 Belair key needs to be pulled out a little and "jiggled" to work! Maybe now I'll pop open a lock, get the number and get a real key...
05-29-2014, 06:34 PM | #10 | |
That would cure your problem with it.... LockDoc
05-31-2014, 12:23 AM | #11 | |
06-10-2014, 10:18 AM | #12 | |
Yes, if the lock is worn the tryout keys will sometimes operate them as smooth as the original key. Glad you got lucky on yours.... LockDoc
07-05-2014, 08:57 PM | #13 |
Active Member
Good information LockDoc. Thanks for posting this.
Funny story: Years ago I had a 55 stepside and my cousin had a 57 stepside. One day I discovered that my key would unlock and also work in his ignition. I used to mess with him when he parked his truck in the local business parking lots by moving it several spaces or on the other side of the lot. After doing this multiple times I finally told him that my my key worked in his lock.
Fleet '66 ***************** '66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade '64 C-10 LWB BBW near future project - "The Wife's Ride" '58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show |
03-13-2023, 07:50 PM | #14 |
I thought I would bump this back to the top just for grins. LockDoc '
03-14-2023, 01:54 AM | #15 |
Great info for the push button brigade.
I can't find the photo of the 47/51 door lock code on the cylinder but I have the how to pop the lock out of the door tutorial on my photobucket page and the code is easy to find on the cylinder. https://app.photobucket.com/u/mr48ch...4-736a87f98af4 I'll put taking some new photos and adding them to the album on my list for tomorrow.
