05-27-2014, 07:51 PM | #1 |
292 crate engine
I was seeking a youtube video for setting timing on a 250 six. One of the video options on right side of screen had StaceyDavidGearZ opening an early 60's 292 crate engine that came from factory. I believe the video is from 2011. It may be a good reference/pictoral for some of you. Enjoy. Oh yea, the video is called "Vintage Hot Rod Straight 6". Obviously, he tricked it out.
05-28-2014, 10:43 AM | #2 |
Post Whore
Re: 292 crate engine
Its actually not a 292 in the vid. Stacey totally screwed up on it....if you listen closely he first says its a 292 outta 1971..then he says its been sitting on someone's garage since 1965...its simple to explain its not a 292 by the 4 inch side covers and the fuel pump being directly behind the distributor. The engine no doubt is a 250. This vid has been posted in the "Tricked out chevy 6 cylinders" thread. But thanks for posting.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-28-2014, 11:43 PM | #3 |
Hey TJ. I posted a reply earlier and I must have done something wrong. Not sure if I've got the hang of this forum yet. Guess I should've recognized the engine, I have a 250. I hope some users have benefited from the post.
05-29-2014, 09:42 AM | #4 |
Post Whore
No biggie..its a great vid..and has some good info, but you can do waaaaay more to these engines then what Stacey mentioned. Kinda like my 292. lol
05-30-2014, 08:03 AM | #5 |
Six in a row makes it go...
Maybe ten years ago or so, you could still get a 292 from GM. Dunno if or when that stopped.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
05-30-2014, 05:09 PM | #6 |
Thought it was kinda funny that Stacey just happened to have 3 webers on the shelf. Anyway, I like the mods to your engine!
Regarding nos parts, I was informed by a former employee of GM Parts that GM didn't store "bigs" beyond 10 years. As an employee, you can call an offsite department of GM and occasionally find "smalls". Can't imagine engines, trannies, or anything like that still available. |
05-30-2014, 06:08 PM | #7 | |
Post Whore
05-30-2014, 06:45 PM | #8 |
TJ. Just for fun, I quickly looked back at a couple of slides on Stacey's video. It does appear to be smaller than a 292 based on side plates and position of motor mount. However, I was wondering if it weren't a 70's engine (as he said) based on the valve cover. It appears it has an opening for a large tube that runs to air cleaner. Probably first of emission requirement unless its a CAL. engine. Also noted that he called the carbs "Carter". Was he wrong on that too?
05-30-2014, 07:51 PM | #9 | |
Post Whore
Edit. Link to vid. https://www.youtube.com/watch?v=3K95OEKP22k
05-31-2014, 01:36 AM | #10 |
Actually, Carter was the original manufacturer of the AFB (Aluminum Four Barrel) carb that Edelbrock now makes under license (or something); Carter also made a ton of other carbs for all kinds of applications.
05-31-2014, 08:27 PM | #11 |
Post Whore
Yeah..that's what I meant..in general..lol..round here you mention Carter an everyone knows yer talking about Edelbrock. lol
