Old 05-27-2014, 08:23 PM   #1
Custom/Ten
Custom/Ten's Avatar
Black wire to trans, what is this?
What is this black wire to the trans for, it's a three on the tree 1972 Custom/10 with a 250 i6Name:  image.jpg
Custom/Ten is offline   Reply With Quote
Old 05-27-2014, 08:24 PM   #2
Custom/Ten
Custom/Ten's Avatar
Re: Black wire to trans, what is this?
Old 05-27-2014, 08:25 PM   #3
Custom/Ten
Custom/Ten's Avatar
It goes to here,Name:  image.jpg
Old 05-27-2014, 09:26 PM   #4
425HP409
425hp409
425HP409's Avatar
It should be for the backup light switch.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 05-27-2014, 10:47 PM   #5
Custom/Ten
Custom/Ten's Avatar
Ok thanks 425HP409 ill go out tomarrow and pull that plug and see if the backup lights stop working.
Old 05-27-2014, 10:57 PM   #6
ray_mcavoy
Originally Posted by Custom/Ten View Post
What is this black wire to the trans for, it's a three on the tree 1972 Custom/10 with a 250 i6Attachment 1259309
I believe that black wire connecting to the transmission is for the TCS (Transmission Controlled Spark) emissions system.
The backup light switch for the 3 on the tree is located on the steering column and has 2 wires (light & dark green).
ray_mcavoy is offline   Reply With Quote
Old 05-28-2014, 12:22 PM   #7
Custom/Ten
Custom/Ten's Avatar
Yea maybe that is a TCS relay in the second picture. All I have seen before are inside the cab above the horn relay though, not here.
Old 05-28-2014, 01:39 PM   #8
geezer#99
geezer#99's Avatar
The switch on the tranny that the black wire hooks to is the ground switch.
When you shift to third a lobe on the shifter shaft contacts the switch and the tcs is grounded thru the tranny.
geezer#99 is online now   Reply With Quote
Old 05-28-2014, 01:46 PM   #9
Custom/Ten
Custom/Ten's Avatar
I'm gonna see if I can find a wiring diagram for TCS. Maybe I can fix it. Right now the blue and brown/white wire are hooked up to nothing.
Old 05-28-2014, 01:58 PM   #10
geezer#99
geezer#99's Avatar
Do what ever you like. Hooked up hurts nothing. No power to the relay so you don't need it grounded. It's all just along for the ride.
You can't remove that switch on the tranny though. IIRC it's an odd ball thread size so a normal plug won't fit.
Old 05-28-2014, 02:00 PM   #11
Custom/Ten
Custom/Ten's Avatar
Ok thanks geezer
Old 05-28-2014, 07:48 PM   #12
Custom/Ten
Custom/Ten's Avatar
Yea, it's definitely the wire for the TCS sensor. I like a clean look so i removed the wires and relay and got rid of everything but the sensor and the black cap on it. Then I spent an hour cleaning the trans lol. Thanks for everyone's help!
