Old 05-28-2014, 01:49 AM   #1
70blackfish
anyone switch to the 4150 base EFI ???
looking into some of the kits from HOLLEY, EDELBROCK, FAST, MSD...
any info would new great. i have read stuff but want real world experience....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-28-2014, 10:41 AM   #2
ls1c10
ls1c10's Avatar
Re: anyone switch to the 4150 base EFI ???
we have installed one powerjection 3 and working on the second as we speak. It works great and gives it a old school look.
ls1c10 is offline   Reply With Quote
Old 05-28-2014, 12:53 PM   #3
Matt Cramer
First question - what are your goals with the conversion? What are you looking to accomplish - better drivability, the ability to handle 20 psi of boost, traction control, or what?
Second - what features will you need the ECU to run?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-28-2014, 03:02 PM   #4
70blackfish
Better drivability. Better mileage. I have a holley 600 DP. Runs and starts fine
Old 05-29-2014, 09:23 AM   #5
Fitz
The available 4150 replacement units cost between $1800.00 and $2800.00 after you purchase the ECU and fuel pump. Since these are "open loop" systems they will never increase gas mileage up to the numbers a modern closed loop system is capable of maintaining. You might see a two to three mpg increase at best. It will take longer than the truck will live to get the mileage increase to pay for the conversion. Besides, you say your truck starts and runs fine. At 300.00 a pop you could buy a bucket full of brand new carbs for the cost of a throttle body injection system so why not stay with what you have?
Fitz is offline   Reply With Quote
Old 05-29-2014, 11:36 AM   #6
Matt Cramer
My experience has been that TBI type setups are often a step up over a carb, but don't do as well as a full multi-port injection setup when it comes to drivability and mileage.
Matt Cramer
4.8 LS build thread
Old 05-29-2014, 11:47 AM   #7
chevy72blu
chevy72blu's Avatar
IMHO these setups made a lot more sense before the popularity of LSx swaps. Lots of members have swapped in complete 5.3 for not much more than an efi kit with dramatically better results as far as mileage and drivability
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-29-2014, 02:41 PM   #8
Matt Cramer
That's what I did.
I had strongly considered putting EFI on the 350. Until I found it had a cracked block.
Matt Cramer
4.8 LS build thread
Old 05-29-2014, 03:46 PM   #9
70blackfish
I decided there must be a good reason these kits aren't flying off the shelf.
its because there not worth the 3k and labor, and not 100% trouble free. if i get one and install and it works i would be lucky.....to me thats not worth 1500. let alone 3k.
SO vintage air is coming in the brown truck.....and it was cheaper buy half
Old 05-29-2014, 05:12 PM   #10
Z10
Z10's Avatar
I went a different route and used the FIRST TPI set up. I think the complete kit, including manifold, injectors, computer, chip, throttle body, & harness is just under $2k. Take a look at my build thread for more info.
I've got about 2500 miles on the system and it's running very well.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
