Old 05-28-2014, 11:08 AM   #1
62k10&84k20burb
62k10&84k20burb's Avatar
where to find build sheets?
Anone know where the factory build sheet could be hidden in a 1968 gmc? Always knew they were hidden, just have no idea where..any ideas?
62 k10 235/sm420
68 3500 250/sm465/eaton ho72/5.14s
84 burb k20 350/700r4/14bsf/10b 3.73s
62k10&84k20burb is offline   Reply With Quote
Old 05-28-2014, 11:10 AM   #2
LSUMurse
LSUMurse's Avatar
Re: where to find build sheets?
I've seen people find them in the coil mesh of the back of the bench seat. Mine was not there, couldn't find one.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 05-28-2014, 11:14 AM   #3
62k10&84k20burb
Like under the upholstery?
62 k10 235/sm420
Old 05-28-2014, 11:27 AM   #4
LSUMurse
LSUMurse's Avatar
Between the wire and the burlap, from what I understand.
http://67-72chevytrucks.com/vboard/s...=370818&page=2
Post # 37 shows one in the seat.
Old 05-28-2014, 11:34 AM   #5
62k10&84k20burb
Thanks! Gonna go search a bit
62 k10 235/sm420
Old 05-28-2014, 12:15 PM   #6
Keith Seymore
Keith Seymore's Avatar
They were supposed to be thrown away, but it was usually just easier to leave them in place and build the truck up around it.
As mentioned, the seats are a good place to look. Also under the carpet, behind any interior trim (if any), under the dash, etc. Passenger cars often have them above the fuel tank but it varyies by model year, assembly plant and even by shift within the same assembly plant.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-28-2014, 12:54 PM   #7
62k10&84k20burb
No luck so far..but did find the rubber for my clutch pedal!! Hahaha
62 k10 235/sm420
Old 05-28-2014, 02:58 PM   #8
62k10&84k20burb
If I were to contact chevy with the vin, do they still have the build on file? Seems like a dumb question....anyone ever try?
62 k10 235/sm420
Old 05-28-2014, 03:20 PM   #9
jocko
jocko's Avatar
nope. But, make sure to check both the seat back and bottom - use a little mirror to stick back there - should be visible if it is in fact there. Mine had TWO build sheets on it when I took it apart. One on the back and one on the bottom. And neither one matched the truck... Ha. Someone replaced the seat with parts from two different trucks
Old 05-28-2014, 03:37 PM   #10
62k10&84k20burb
Will search harder then...and behind the dash etc.
62 k10 235/sm420
Old 05-29-2014, 08:12 AM   #11
Keith Seymore
No. Only '77 and newer ('76 for GMC).
http://www.gmmediaarchive.com/
K
1979-1986
1986 - 2019
