05-28-2014, 12:31 PM | #1 |
8 lug to 5 lug conversion - what do do with the rear end
I'm considering changing from a 8-lug wheel pattern to a 5-lug wheel pattern. With the front I am thinking about going with EarlyClassic.com's C20 3/4 ton to 1/2 ton spindles and getting the 5-lug rotors.
My question is what do I do with the rear end. It is an 8-lug 14 bolt rear. The truck is a 1985 GMC Sierra Classic 2500 3/4 ton crew cab LWB. The ultimate goal is to install a PorterBuilt DropMember front and rear.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
05-28-2014, 03:31 PM | #2 |
Never Ending Projects
Re: 8 lug to 5 lug conversion - what do do with the rear end
You will likely need to swap out the rear end for a 5 lug 1/2 ton version. Should be tons of them available in any junk yard. Find one with the right rear end ratio that you want. Should bolt right. You might need the 1/2 ton driveshaft as well, as I think the u-joints are different then 3/4 ton.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-28-2014, 03:46 PM | #3 |
They make conversion hubs but they are expensive. It would be cheaper to find a used 5 lug.
You can get conversion spacers (though there is a safety concern with that for some).
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-28-2014, 04:11 PM | #4 |
Biggest issue is likely going to be the center hub size. 8 lug hub bore is huge compared to a 5 lug setup. I don't think you would find 5 lug wheels that would fit over the hub, unless you used an adapter that made it flush with the end of the hub.
06-03-2014, 05:05 PM | #5 |
The real question is why?
06-03-2014, 05:23 PM | #6 |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
06-03-2014, 06:23 PM | #7 | |
06-03-2014, 08:49 PM | #8 |
I am going to install a full Porterbuilt air ride suspension on it; bought it with this sole intent. I thought keeping with the 8-lug setup would help make is standout a little from other dropped C10's but the wheel selection is severely limited with the 8-lug for the sizing and fitment I'm looking for versus the 5 lug patter.
06-04-2014, 12:32 PM | #9 |
Answers my question.
06-04-2014, 01:07 PM | #10 | |
Check out these (you have to scroll down a bit to get past all the dually rims): http://4wheelonline.com/American_Force_Wheels.29008
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 06-04-2014 at 01:15 PM. |
