05-28-2014, 02:29 PM | #1 |
Outer Tie Rod Ends Torque Specs??
1985 GMC K2500 4x4 VIN M
I'm currently replacing tie rod ends and the steering stabilizer. If anyone has the torque specs for the castle nut on the out tie rods ends that would be great! When i started working on this truck i realized the previous owners messed a lot of things up. I couldnt figure out why my master cylinder would not stop leaking from the cover.... then after some home work they had a 1/2ton MC installed on my 3/4ton HD truck. no good lol. So when i started this tie rod job i realized the same problem was back again. They installed 7/8 Thread tie rod/centerlink setup from a 1/2ton on my truck. FOOLS!!! lol Anyway, the torque specs would be great! and is there a free website or something that list all of the torque specs? Thanks |
05-28-2014, 07:42 PM | #2 |
Re: Outer Tie Rod Ends Torque Specs??
bump
05-28-2014, 07:55 PM | #3 |
From what I have it says Tighten the steering linkage nuts to 45 ft. lbs. Nothing for the specs for the castle nut on the out tie rods .
Trueman Last edited by 463; 05-28-2014 at 08:01 PM. |
05-29-2014, 07:36 AM | #4 |
Java Mechanic
I don't think there is a torque for that since you have to line it up with the hole in the tie rod end to put the cotter pin in.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
05-29-2014, 10:08 PM | #5 |
I did 35ftlbs plus 1/3 turn and it actually lined up nicely with holes for cotter pin. Thanks
