05-28-2014, 03:29 PM | #1 |
Bolt Pattern?
VERY QUICK QUESTION!
I've got a 1975 C20 Camper Special, with the 4:10 gear ratio. 8 Lug bolt pattern. But what is the exact pattern, 8x____? Thanks
If It runs like a Chevy, it probably is! |
05-28-2014, 05:00 PM | #2 |
Re: Bolt Pattern?
6.5
05-28-2014, 05:01 PM | #3 |
Re: Bolt Pattern?
8x6.5" I think
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
05-28-2014, 09:06 PM | #4 |
Re: Bolt Pattern?
Thanks guys. So wheels from a 2013 Silverado 2500 with the same bolt pattern will fit?
05-28-2014, 10:47 PM | #5 |
Re: Bolt Pattern?
No, anything 2010 and older would fit. The suspension and brakes were redesigned for 2011 and a different wheel pattern was used.
05-29-2014, 02:58 AM | #6 |
In the Forgotten far North.
Re: Bolt Pattern?
MEASURING BOLT PATTERNS.
4,6 & 8 LUG PATTERNS; Measure center to center of two holes directly across from each other 4 LUG 5 LUG PATTERN IS MEASURED DIFFERENTLY THAN THE OTHERS...Measure from the CENTER on one hole to the BACK of the third hole. This is the easiest and most accurate way to "Estimate" a 5-lug bolt circle. You can also measure from the CENTER of one hole to the CENTER of the third hole using 1.05 multiplier to find your bolt circle. 5 LUG 6 LUG 8 LUG
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
05-30-2014, 01:57 PM | #7 |
Moderator
Re: Bolt Pattern?
For a long time GM, Ford, and Dodge used 8 x 6.5"... i used a set of AL wheels from a T800 chassis and have used the steelies from my 2000 T400 on the 76. You'll need dual thread lug nuts for the center caps.
The GM T900 chassis changed to 8x180mm for MY 2011. Vans lagged... More in this thread...http://67-72chevytrucks.com/vboard/s...d.php?t=564112
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
