05-28-2014, 10:58 PM | #1 |
Aftermarket steelies and factory hub caps?
I searched, but didn't find an answer.
I'm looking to upgrade the brakes on my 1967 C10 to discs, which requires a wheel change. I'm a nerd for originality, so I'd really like to end up with 15x8 steel wheels (6x5.5) with my factory hub caps when it's all said and done. What are my options? Coker? Speedway? Later model OE Chevrolet? Pics for clicks: |
05-29-2014, 04:40 AM | #2 |
Re: Aftermarket steelies and factory hub caps?
Those caps should fit any standard steel wheel (drum or disc). Find any standard ralley wheel to test them.
05-29-2014, 09:48 AM | #3 |
Scoti nailed it. I have the stock wheel covers and aftermarket rally wheels on my GMC. You should be fine any way you go.
05-29-2014, 03:10 PM | #4 |
Awesome. Thanks, fellas.
