Old 05-28-2014, 11:01 PM   #1
davepl
davepl's Avatar
Can anyone check 3/4 ton disc brake line size for me?
I'm converting a '70 Longhorn over to '72 discs (also 3/4 ton).
I need to know if the factory changed from 3/16 front hard line to 1/4 when they went to disc brakes in the front. I just can't find anything that says anything either way.
I ordered a repro front brake line kit but even though it's sold as 3/4 ton it's clearly for a 1/2 ton and useless to me, let alone to use as an indication of what is "right".
Anyone have a 3/4 ton and a pair of calipers? I'm looking for the diameter of the hard line between the prop valve and the T fitting (the part that goes down to the frame). If you're ambitious it'd be good to know the diameter between the T and the flex hoses too.
Although many argue that tube diameter doesn't really have much if any effect, especially on short runs, I'd like to do this once and do it right. On the other hand I don't want to redo all of that damned stainless if 3/16 is already right for it!
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-28-2014, 11:54 PM   #2
airdale94
airdale94's Avatar
Re: Can anyone check 3/4 ton disc brake line size for me?
Ideally you want 3/16" diameter with front disc and 1/4" for rear with wheel cylinders. The reason I was told was with front disc it's not the volume you need but the pressure. Smaller line, higher pressure. With the rear you don't need the pressure but want the volume. With that being said I just swapped a 14 bolt out of a early 80's and had to use 3/16'' to connect the wheel cyls. so... I would keep the 3/16 because I don't know that they ever switched to 1/4 on the front.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 05-29-2014, 12:14 AM   #3
mgchevyparts
mgchevyparts's Avatar
There is no pressure difference due to line size and either size will work fine.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 05-29-2014, 06:32 AM   #4
JointTech
JointTech's Avatar
ill measure it tomorrow for you. I just put in new lines and still have the old ones.
who did you get your SS from? I got mine from inline tube.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-29-2014, 06:34 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That is true. Line size does not affect pressure in any way.
Old 05-30-2014, 05:29 AM   #6
JointTech
JointTech's Avatar
Hopefully this helps.
72 C20 Long Bed
Old 05-30-2014, 01:56 PM   #7
davepl
davepl's Avatar
Any idea which two are the .255 lines? Since I'm stuck with making my own, I can't ID them easily from looking at them.
Old 05-30-2014, 01:59 PM   #8
JointTech
JointTech's Avatar
pic #2 is the piece that connects to the long piece that goes down the frame.
it goes across the cross member and then connects to #4 which goes up to the prop valve.
72 C20 Long Bed
Old 05-30-2014, 02:11 PM   #9
davepl
davepl's Avatar
So if I'm reading it right, both #2 and #4 are for the rear brakes then? And they're both 1/4" while everything for the fronts is 3/16?
Old 05-30-2014, 02:14 PM   #10
JointTech
JointTech's Avatar
yup. you said you wanted the front lines all measured. well those are at the front of the truck but yea they are for the rear brakes.
Im pretty sure #1 goes to the passenger caliper and #3 goes down from the prop valve.
the one to the drivers caliper is just a short L shaped piece which Im not sure why I didn't get a picture. sorry.
72 C20 Long Bed
Old 05-30-2014, 03:10 PM   #11
tony58
Are you doing this so it looks original? Because as already pointed out there is no difference in your brake performance or pressure due to line size.
tony58 is offline   Reply With Quote
