Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-28-2014, 11:28 PM   #1
71Dragtruck
71Dragtruck's Avatar
Motor plate guys
How much did you leave on your motor plate when you trimmed it down? I have my pattern at this stage right now, I had more on the outer edges as when I finish off my cage I'd like to attach a couple more tabs from the forward bars to the plate, then trimmed it a bit more.
I think I should still be able to add the extra attachment point if I cut it like this, if you run a motor plate please post some pictures of how you did yours.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-29-2014, 12:52 AM   #2
chevytruck1970
chevytruck1970's Avatar
Re: Motor plate guys
I trimmed mine to the exact width of the frame.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 05-29-2014, 01:06 AM   #3
71Dragtruck
I was thinking supports off the bars to the plate like you did, thanks for the picture.
Sponsored by:
Hard Candy Customs
Old 05-29-2014, 01:08 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I"m no help, but 71dragtruck, your engine bay is purdy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-29-2014, 01:16 AM   #5
Super73
Super73's Avatar
Mine is like yours in the pic but flush with the outer edge of the frame.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-29-2014, 01:20 AM   #6
chevytruck1970
Here's a picture of the mount without the plate in the way.
Justin
1.35 60ft
Old 05-29-2014, 01:51 AM   #7
71Dragtruck
Yes that's exactly how I was thinking of tying it in.
Sponsored by:
Hard Candy Customs
Old 05-29-2014, 01:54 AM   #8
71Dragtruck
Not sure why my template looks like it hangs over the rail so much and angles out in the picture???
It is actually only about 1/4 over the edge and goes straight up on the sides.
Sponsored by:
Hard Candy Customs
Old 05-29-2014, 08:11 AM   #9
chevytruck1970
Are you going to install a mid plate also?
Justin
1.35 60ft
Old 05-29-2014, 08:45 AM   #10
71Dragtruck
Eventually yes, have one ordered but right now there is a header tube in the way, have it booked for a set of custom headers this fall so will risk this season without one. I can leave the passenger side motor mount on if that would make any difference but the drivers has to go, and a limiter bar will go in, or both mounts out, and a pair of limiters in are my current options.
Sponsored by:
Hard Candy Customs
Old 05-29-2014, 08:45 AM   #11
regan wilson
regan wilson's Avatar
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 05-29-2014, 08:49 AM   #12
regan wilson
Mine is mounted to a plate that spans the frame rail top to bottom. Thats the best pic I have. You will also need to do something with engine limiters. Mine bolt to the old motor mount bosses on the block. They then went forward to the old crossmember. Make sure you use a quality rubber trans mount.
Old 05-29-2014, 11:20 AM   #13
71Dragtruck
I'm running a Prothane poly mount and have a limiter for both sides.
Sponsored by:
Hard Candy Customs
Old 05-29-2014, 05:58 PM   #14
vin63
It's Better With Nitro
vin63's Avatar
I fab'd my chassis mounts to index the motor plate, so I didn't have to muscle anything around - I welded a small tab as a lip for the bottom of the plate, and machined the angle on the ends of the plate to correspond with the angled vertical of the chassis mount - this worked as guides as the engine was dropped down.
…it ended up being a smaller version of Jerry Bickel's plate mount:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-29-2014, 09:33 PM   #15
71Dragtruck
Very nice Vin, got mine trimmed down, time to mount it and round the edges.
Sponsored by:
Hard Candy Customs
Old 05-30-2014, 07:45 PM   #16
Marv D
Registered Truck Offender
Marv D's Avatar
Vacuum pumps water pump etc is intended to be on the face of the motor plate.
But..... Alternators are always a PITA,, plan ahead
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-30-2014, 10:27 PM   #17
71Dragtruck
Got that covered Marv
Sponsored by:
Hard Candy Customs
