Old 05-29-2014, 01:04 AM   #1
slammed90
slammed90's Avatar
84 c20 ignition cylinder
Anyone kno how hard it is to install a new cylinder switch...lost keys so had to buy a new one just don't kno if it will b an easy install...any help would b greatly appreciated thanks
"NO BAGS JUST PLAIN LOW"
slammed90 is offline   Reply With Quote
Old 05-29-2014, 08:57 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 84 c20 ignition cylinder
well as long as you have the right tools.. the steering wheel remover and the compress tool to compress the large washer type thing under the wheel so you can remove the lock ring its quite easy.. the rest are basic tools like a screwdriver and quarter inch drive socket set
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-30-2014, 03:37 PM   #3
slammed90
slammed90's Avatar
I was googling this a while back n saw these instructions forna 84 silverado idk if its accurate though.... http://www.ehow.com/how_6123806_remo...do.html#page=0
Old 05-30-2014, 03:37 PM   #4
slammed90
slammed90's Avatar
It just shows u just need basic tools
Old 05-31-2014, 01:50 AM   #5
meter swinger
meter swinger's Avatar
What rusty old c10 said. First remove the nut that holds the wheel. Then put the wheel puller on by threading the two side bolts of the puller into the holes on both sides of the wheel. Crank down on the center bolt of the puller until it frees the wheel. Once the wheel is off you will see a large round plate. This is the spring plate. It has a spring underneath it and a lock ring on top facing you. This is a lock ring not a snap ring, and the best way i have found to get it off is by working it off with a small flat screwdriver by tapping the screwdriver with a hammer. It is made out of wire and will distort a little when removed so re-shape it with pliers before you reinstall it. Once that is off if I remember correctly you need to remove the plastic mechanism for the turn signal ( im going off memory here its been awhile) that is held down by three screws. Once the signal assembly is removed you will see a screw to the right near the tumblr. Remove this screw ( bolt actually) and then the tumbler will slide out of its hole. Reinstall everything in reverse.
The whole job looks worse than it really is.
meter swinger is offline   Reply With Quote
Old 06-01-2014, 08:03 PM   #6
slammed90
slammed90's Avatar
Thnks guys did the swap yesterday...now on to figuring out wich ones are my tailights in all the bunch of wires in the back...(used to b a utility truck n now putting a regulat ned on it)...but has all the trailer wiring n stuff
