Old 05-29-2014, 01:24 PM   #1
Custom/Ten
Custom/Ten's Avatar
PVC and brake booster plumbing, is this a bad setup?
Just read that pcv should have its own vacuum, is this a bad setup? All parts seem to function correctly but a haven't taken it out and given it h3ll. I just took it out for a couple lazy drives. Name:  image.jpg
Custom/Ten is offline   Reply With Quote
Old 05-29-2014, 01:25 PM   #2
Custom/Ten
Custom/Ten's Avatar
Re: PVC and brake booster plumbing, is this a bad setup?
Wiring will be moved, I'm workin on that now.
Old 05-29-2014, 02:20 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's the other way around... the booster should have it's own vacuum line so it gets full vacuum from either the intake manifold or the carb. The PCV can be T'd in to another vacuum source.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-29-2014, 02:31 PM   #4
Custom/Ten
Custom/Ten's Avatar
Size:  39.3 KBWhere should the booster go? Here maybe if I can find a fitting for it?
Old 05-29-2014, 08:11 PM   #5
mgchevyparts
mgchevyparts's Avatar
Gary
Correct. you can have very small things connected with the booster but a PVC is not one of them. Things like tranny modulator, distributor vac advance are ok since they don't draw any flow away from the booster.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 05-29-2014, 08:59 PM   #6
geezer#99
geezer#99's Avatar
Originally Posted by Custom/Ten View Post
Attachment 1259891Where should the booster go? Here maybe if I can find a fitting for it?
That will work. Look for this type of fitting in the size you need.
http://www.fastenal.com/web/products/details/69945
Old 05-29-2014, 10:54 PM   #7
Lattimer
Lattimer's Avatar
Last time I needed one the local NAPA had all of those fittings in stock.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-30-2014, 12:15 AM   #8
Custom/Ten
Custom/Ten's Avatar
Thanks everybody, ill take your advice and get that sorted out.
Old 05-30-2014, 07:03 AM   #9
Fitz
is this a bad setup? Attachment 1259886
Yes.
Fitz is offline   Reply With Quote
Old 05-30-2014, 07:06 AM   #10
Fitz
Yes. Your booster needs full vacuum to support braking. The PCV connection lowers the vacuum pressure to levels where your brakes might not work at times when the engine vacuum normally falls.
Old 09-10-2014, 02:36 PM   #11
thelawdoc
Fitz, when you say the brakes might not work, do you mean that the boost will not work, making the effort to brake be that of manual, non-assisted brakes? Or do you mean a complete failure of the brakes? I ask because it has been on my mind to be rid of my brake booster.
thelawdoc is offline   Reply With Quote
Old 09-10-2014, 04:43 PM   #12
88Ironduke
The little check valve assembly is supposed to act a check valve for vacuum and hold the vacuum in the booster more or less at the highest point available. It is the surprise factor that Fitz is speaking of. The brakes will operate but if vacuum or is insufficient it will feel like manual brakes. The surprise will feel like you're trying to push a cinder block thru the floor boards when it should be smooth and nice. The port that is pictured is where I tapped from for my 250 as well, thinking 1/2 NPT"???
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
