Old 05-29-2014, 04:02 PM   #1
duckdude
heater out of wack
I think my heater controls are out of adjustment. this thing keeps cranking out hot air no matter where the controls are at. any ideas? not sure on what position the cables need to be in in relationship to the placement on the controls.
duckdude is offline   Reply With Quote
Old 05-29-2014, 10:42 PM   #2
davischevy
davischevy's Avatar
Re: heater out of wack
Heater only, or do you have factory air?
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 05-30-2014, 12:29 AM   #3
heathbirkendahl
Having the same issue.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 05-30-2014, 03:49 PM   #4
duckdude
factory air
Old 05-30-2014, 04:13 PM   #5
davischevy
davischevy's Avatar
On the right inner fender, there is a valve in the heater hose with a little vacuum line running to it. When you turn on the AC the vacuum from the control panel closes the flow of hot water.
I would first pull vacuum on the valve. If it holds, you are losing vacuum somewhere between the control panel and the valve. You will have to pull the glove box, and check the vacuum line behind it.
other Larry
Old 05-30-2014, 04:15 PM   #6
davischevy
davischevy's Avatar
Andy4639 posted some good info here
http://67-72chevytrucks.com/vboard/s...d.php?t=630411
other Larry
Old 05-30-2014, 09:33 PM   #7
duckdude
thanks a bunch. now I have a place to start looking for problems
Old 05-30-2014, 09:44 PM   #8
tlcrz1972
tlcrz1972's Avatar
Don't rule out the mixing door between the evaporator and the heater core. It could be a cable issue or leaves and dead mice preventing it from operating correctly.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
