Old 05-29-2014, 06:35 PM   #1
hotrod66
hotrod66's Avatar
250 to a 292
i was wondering if any one knew if there was any difference in the passenger side motor mount for the 292 or if it is the same one just moved forward.
thanks
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 05-29-2014, 06:45 PM   #2
padresag
Re: 250 to a 292
292 has a different passenger side perch
ron
padresag is offline   Reply With Quote
Old 05-29-2014, 09:38 PM   #3
paintman
Re: 250 to a 292
when I did the switch my 292 it had a slightly different bolt pattern on the passenger side. I was able to use the bottom 2 holes, but the top hole was way off. I had to weld/fill in the hole and re-drill the mount.
paintman is offline   Reply With Quote
Old 05-30-2014, 07:59 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 250 to a 292
ron
Indeed. It's located differently. The pic below of the fresh painted engine is a 250. See that the engine mount is aft of the fuel pump. The dirty engine is a 292 and you can see (sorta) that the fuel pump is aft of the mount.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
