Old 05-29-2014, 08:02 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Clutch/fan install Q
Mr. Brown came today!! I got my fan clutch and new blade today. Are there any tips, tricks or warnings about taking out the flex fan and installing the new set up?? Any info is appreciated.
Thanks!!!!!!
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 05-29-2014, 10:52 PM   #2
Mick Je
Mick Je's Avatar
Re: Clutch/fan install Q
Loosen the bolts on the flex fans before you take the belts off, this keeps the fan from spinning while trying to loosen the fan. Flex fans are super sharp!!! Found that out the hard way!!!
Good Luck!!!
343 NEVER FORGET 9-11
FIGHT ON!!! GO USC!!!
PROUD OWNER OF A 1970 1/2 TON
Mick Je is offline   Reply With Quote
Old 05-29-2014, 11:10 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Lime mick said above and i suggest a heavy long sleeve shirt and work gloves when removing the flex fan.
WIDESIDE72 is offline   Reply With Quote
