05-29-2014, 09:04 PM | #1 |
Dodge Durango Fuel Door
I plan on installing a Boyds welding tank In my 71 fleetside shortbed.Going to use the marker light as the filler door,I took the idea from Hart Rod he has a really good thread on how he installed his.Not going to cut the inside of the bed everything will look factory from the outside.I went to the local U pull it and probably looked at over 500 different cars/trucks.Needed one that did not hit the inside panel when it closed,the one that seems to be the best is the 1998-2003 dodge Durango fuel door.
My truck is in the paint shop now but I have a dummy panel that I bought off another member that is being used for mock up.Works out good for pics because you can see the swing of fuel door arm. I will post more pics over the next few weeks to show you how it turns out Today was just to see how it fit seems like it might work out after some trimming. Open to Ideas Thanks Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
05-29-2014, 09:19 PM | #2 |
Re: Dodge Durango Fuel Door
More pics after I removed the outer fuel door skin.
I plan on attaching a small filler panel where the screws are.
05-29-2014, 09:58 PM | #3 |
Nice, looking forward to the finished door.
