Old 05-30-2014, 11:58 AM   #1
bobby204
Tach Wires
I just picked up a 69 C/10 that has a 350 w/auto and a tach cluster in it.The tach is not working so I started back tracking the wires and found that the red wire is not hooked up.One wire goes to the coil but I dont know where the red one goes.Any help would be great.
Thanks Bobby
bobby204 is offline   Reply With Quote
Old 05-30-2014, 12:01 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Tach Wires
It plugs into your fuse panel. Plug it into the "cluster feed terminal on the fuse panel and you should be good.
If you need any further help or parts, let me know.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-30-2014, 12:03 PM   #3
bobby204
Re: Tach Wires
OK will give it a try.
Thanks Bobby
Old 05-30-2014, 12:03 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: Tach Wires
Brown wire goes to negative terminal on your coil, pink wire goes to 12v keyed power source. Make sure tach is grounded or it will fry. Tach is grounded through the cluster, but it never hurts to add a dedicated ground wire to the tach.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-30-2014, 12:09 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Tach Wires
Even better advise from leddzepp Just make sure you have the 12V to a fused location. If you ever have a voltage regulator that sticks, it will blow the fuse and save the tach. No fuse = fried tach.
Old 05-30-2014, 12:17 PM   #6
bobby204
Re: Tach Wires
so if I wire up a fuse to the location you have circled in the pic will I be ok.
Bobby
Old 05-30-2014, 12:22 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Tach Wires
Bobby
Do you have a 12V test light? If so, touch it on the terminal I circled and the test light should light. If you pull the fuse just to the right of my circle, the test light should go out. That is how you know that that terminal will be a fused terminal. If you want, you can wire in an in line fuse holder as well. You will have to have the key in the run position to do this.
Old 05-30-2014, 12:32 PM   #8
bobby204
Re: Tach Wires
I checked it with a test light and no power to the post circled but had power to the fuse.Bobby
Old 05-30-2014, 12:39 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Tach Wires
Did the fuse have power on both sides? You can hook it anywhere on the fuse panel that has 12 volts as long as it only has power when the key is in run position and the red wire is fused.
Let me know,
Tom
Old 05-30-2014, 12:41 PM   #10
bobby204
Re: Tach Wires
OK thanks for all your help.
Bobby
