Vintage Air Drain Line
I did not want to drill another hole in the firewall for the drain line so we made the hole through the floorboard right at the area where the flat section meets the angled portion. That way the water will drain out through the floorboard. We extended it about half an inch below the floorboard. Now the water runs out straight to the ground. We filled in around the hole with a rubber compound putty to secure the tube so that there are no rattles as well as eliminating the open space.
1953 Chevy 3 Window Truck 3100 Series |
Re: Vintage Air Drain Line
A while back there was a post, on this list, about T'ing the cowl vent drain into the VA drain line. I kept the cowl vent so that is the way we are going to drain it also - I think that's a good way to run the drain.
![]() Join Date: Dec 2012
In my '59 is there a way I can make a drain? where does it normally drain at?
1971 GMC Sierra 1959 GMC 100 |
I get nervous about hidden drains were you may not always be checking for problems. The VA one thru the firewall comes out under the battery box and drops straight down. That is how I ran mine, black on black and you cannot see it (pic is with 2000W light shining). You can only see it on the inside if you look under the dash.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
After filling 45+ holes in the firewall, I am a bit reluctant to make more, even tho I know I really need to - but exactly where........ :)
oh, I know that is why its under the battery box!
on truk i ran the drain straight out the right side behind the fender.
hard to see in this pic under the va unit, but you can see where it goes behind the old fresh air vent. ![]() schrum... vintage air is an after market ac vendor. i don't think your truck has ac other than 2-55 2 windows down at 55 mph ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Why was there so many holes? my truck barely has any
Holes for cables, fasteners, screws, heater and hoses, steering, drain, bolts and rivets. Relocated the PB the person before me had installed too low, + a few I probably don't remember....45 is a close number....
Count your blessings :) |
But his pictures were from an AD and not a TF, so the battery box is under the floor. In this application it's wide open, and very visible.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
![]() Join Date: Mar 2011
I drilled a hole thru the side panel, put brake tubing in the angle I wanted and welded in place. I then put about 15" of hose on the end and ran it below the fender to drain. Here's a pic showing the tube...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
I mounted mine so that it would fulfill 2 desires. One that makes it easy to fix a stopped up drain problem by simply disconnecting it at the plastic tubing/solid tubing connection. Second I did not want to run it through the firewall (creating another hole) with the water running down the firewall. I did not want the water running down any metal. I wanted it to drip down onto the road. Plus the fact I did away with and covered up the cowl vent as well as the side vent.
#13 | |
![]() Join Date: Mar 2007
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
