05-30-2014, 07:28 PM | #1 |
Full battery, wont turn over
Having some kind of starting issue. The truck won't even try to turn over. But the battery is full. 87 TBI 5.7L
What is usually the cause of this? Perhaps a dead starter? Or a dead switchkey? Do starters just up and die, or do they sound different as they get weaker and weaker? |
05-30-2014, 07:47 PM | #2 |
Re: Full battery, wont turn over
Change the starter cables. They oxidize internally with no outward sign any time after ten years or so.
Rich Weyand 1978 K10 RCSB DD. |
05-30-2014, 08:54 PM | #3 |
Check your ground (-).
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
05-30-2014, 09:31 PM | #4 |
No click, nothing at all?
If so, the solenoid isn't starting the starter and the problem is on the low current side. Lights? Horn? Jump the solenoid, or measure the voltage to ground at the solenoid S terminal with the key in the start position. What's the battery voltage? |
05-30-2014, 09:34 PM | #5 |
i agree with rich had the same problem with a toyota one time put a new cable from the starter to the battery no more problem.
05-30-2014, 09:40 PM | #6 |
Cruzin
give the starter a few taps with a hammer see if it moves then.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-31-2014, 02:05 AM | #7 |
Yeah no click, nothing. But I have headlights and everything. I think its the switchkey, maybe. It jiggled it and tapped on it a little bit and it started working. The switchkey has been kind of worn out since I got the truck. You can take the key out while the truck is still running.
Battery voltage is fine at 13.8v |
05-31-2014, 07:04 AM | #8 |
You can jump the solenoid with a screwdriver to verify that the starter has enough current and that it works.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-31-2014, 07:13 AM | #9 |
Cruzin
another thought,if you have a tilt column try moving it up and down, i've have problems with mine where it wouldn't start. Not totaly sure how it all works but think there is a rod in the column that engages the ignition switch under the dash when you turn the key and wasn't doing it in certain locations.
05-31-2014, 04:31 PM | #10 |
You can remove the top cover from the collum and take the bottom cover off and loosen the bolts on the collum bracket until the collum drops a little. Then you can see rod on top of the collum that runs between the ign. Tumbler and the ign. Switch at the base of the collum. Turn the key and press down on the rod with needle nose pliers. If it starts your key tumbler is bad. They are cheap pot metal and have a small tang on them that breaks off.
05-31-2014, 05:11 PM | #11 |
Sounds like maybe some sort of ignition issue in the column. I was originally going to say check your connections on the relay on the firewall above the distributor. I had that issue a while back. The terminals were corroded and not making contact.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
05-31-2014, 07:43 PM | #12 | |
But thanks for all the help everyone! I will try all of these methods to get it fixed |
05-31-2014, 10:41 PM | #13 |
Battery voltage is 12.7 with a full charge so you have a magic battery I guess that's at idle...
The key on column vehicles move a rod connected to a switch down the column a bit. |
06-01-2014, 02:56 AM | #14 |
The wife's toyota says 13.4v at idle and 13.8 at 2k rpm. Its not uncommon
Your battery is probably just old |
06-01-2014, 06:57 PM | #15 |
x2.... Or not magical.
06-01-2014, 09:26 PM | #16 |
try hitting the bottom of the starter with a hammer
06-06-2014, 01:02 AM | #17 | |
Moderator
12.7 maybe just after shutdown before it settles down to 12.2 or so.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-06-2014, 02:48 AM | #18 | |
http://en.wikipedia.org/wiki/Automot...rminal_voltage
06-06-2014, 03:36 AM | #19 |
my neutral safety switch went out on my 78 causing the same problem. At the time, it was a $5.00 part.
06-06-2014, 10:11 AM | #20 | |
Moderator
^^^ Good thing to check ^^^
If she settles to around 11.8-12.5 I'm happy.
06-08-2014, 03:06 AM | #21 |
Dont know what was going on, it seemed to fix itself. Till it leaves me stranded lol
Gotta be either the switchkey or one of those column issues |
06-08-2014, 08:56 AM | #22 |
Well it left me stranded. And you guys saying it was the starter, you must have been right.
Cause I grabbed a hammer and tapped on the starter a few times, and then turned the key again and it started right up. What is the issue? Can I fix this starter? Or do I have to buy a new one? |
06-08-2014, 09:58 AM | #23 |
BAD BOW-Silverado XST
You can have the solenoid replaced. However, most people just opt for a new starter.
06-08-2014, 12:03 PM | #24 |
I kinda want to find the exact problem and fix it myself. I love turning my own wrenches whenever I can.
What exactly does it mean if you can tap the starter with a hammer, and then the problem goes away? Is that the solenoid? Could it also be something else? And just in case, where exactly is the neutral safety switch located? I'll check it out too. |
06-08-2014, 01:24 PM | #25 |
Did you ever change the starter cables? They can be on and off like that.
