Old 05-30-2014, 10:11 PM   #1
BIGglaSS
BIGglaSS's Avatar
55-59 ride height?
I have recently started working on a 57 truck. Camaro clip, bagged. What is a good ride height for ground clearance, measured at the rockers?
BIGglaSS is offline   Reply With Quote
Old 05-31-2014, 01:54 PM   #2
BIGglaSS
BIGglaSS's Avatar
Re: 55-59 ride height?
Maybe pictures will help. Camaro sub, 2" drop spindles, 295/45/18 rear, 235/45/18 front. As the front gets lower, the track width gets wider due to the A-arm angles. How do you decide if the A-Arms are the correct angle at ride height? Right now the clip is only tack welded. Truck frame is sitting on top of camaro sub. Trying to decide whether to go for it and weld it up, or drop the clip a little lower and more level with the truck frame. Moving the clip lower will give me a better A-arm angle and more clearance for the 5.3l LS.
6.5" at front of rocker, 9" at rear of cab
5.5" at front of rocker, 8" at rear of cab
How's the wheel look in the fender opening?
Old 05-31-2014, 03:53 PM   #3
Rednek13x
Rednek13x's Avatar
Looks good! how much did you move the clip forward?
Rednek13x is offline   Reply With Quote
Old 05-31-2014, 04:47 PM   #4
BIGglaSS
BIGglaSS's Avatar
I bought it with the clip already tacked in. I don't know how much it was moved forward from stock center line.
Old 05-31-2014, 06:18 PM   #5
55dude
55dude's Avatar
having driven a 50 that was extremely lowered make sure you have AAA so after you hit debris in road your truck will get home safe. damaged oil and transmission pans are first thing that gets taken out. bottom out at 70 mph and a shock breaks. 4x4 skid plates really help just ask the low rider crowd!
55dude is offline   Reply With Quote
Old 06-01-2014, 12:47 AM   #6
capnduane
capnduane's Avatar
Stock with bigs and littles. '60s hot rod look
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline   Reply With Quote
Old 06-03-2014, 03:59 AM   #7
4Eyedtruck
This truck looks like zr2ricks project any word on what happened with him he had a build thread on here on this truck but last post was 2012 if this is indeed his truck http://67-72chevytrucks.com/vboard/s...d.php?t=484701
4Eyedtruck is offline   Reply With Quote
Old 06-03-2014, 12:02 PM   #8
58CameoAZ
That sure looks like his truck! Hope he is OK and maybe just lost interest
in it,and decided to sell it. the guy had some hard work into it.
Allen
58CameoAZ is offline   Reply With Quote
Old 06-03-2014, 03:46 PM   #9
BIGglaSS
BIGglaSS's Avatar
He is fine and well. I'm excited to have this truck now, and can't wait to get it back on the road. It is still a big project with a long road ahead!
After spending a few days mocking up, and measuring, I'm going with 5.5" at the front of the rocker and about 7" at the back of the cab for ride height going down the road. The drop spindles and the location of the clip don't play nice with the A-arm angles. Big plans ahead!
