Old 05-31-2014, 05:26 PM   #1
dmartin1
dmartin1's Avatar
smacking control arm balljoints in. hammer?
well i took one of my control arms and balljoints to my buddys boat repair shop and his dad and a worker were able to smack the balljoint all the way in nicely with a lead hammer and a few blows.
unfortunately i dont havea lead hammer, and the ones i seen locally are like 60$?
i have a 5lb solid steel and steel handle mini sledge i call my ford hammer.
will this hurt the balljoint or should i go with a lead hammer or some type of dead blow hammer?
what do ya think?
i do not have a press.and my buddys are beyond busy with the river traffic of boats in town thanks guys!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 05-31-2014, 05:37 PM   #2
undertaker72
undertaker72's Avatar
Re: smacking control arm balljoints in. hammer?
if you have a floor jack , or even a screw jack , you can make a press , and they should be pressed not hammered , but you can use a socket or larger piece of pipe and the jack using the weight of your car or a other piece of heavy equipment , might need a helper or three hands , but you can push them in this way
undertaker72 is offline   Reply With Quote
Old 05-31-2014, 05:40 PM   #3
hamjet
hamjet's Avatar
I've been known to find a socket that fits nicely on the bj and lay a piece of hard wood on the socket as not to damage it and drive it home that way.. OOPS! got beat out....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-31-2014, 05:40 PM   #4
dmartin1
dmartin1's Avatar
Originally Posted by undertaker72 View Post
if you have a floor jack , or even a screw jack , you can make a press , and they should be pressed, but you can use a socket or larger piece of pipe and the jack using the weight of your car or a other piece of heavy equipment , might need a helper or three hands , but you can puss them in this way
i do have a few floor jacks and some large pipe thank you very much sir! i will just use our suburban. why didnt i think of this?
65 nova
And more
Old 05-31-2014, 05:40 PM   #5
cdowns
cdowns's Avatar
go to auto parts store and rent(FREE) the proper ball joint press
Old 05-31-2014, 06:45 PM   #6
davepl
davepl's Avatar
"If the tool's not right, the man's not bright."
Put the hammers and jack stands away. We're not stuck on the farm here folks, go rent or buy the right tool.
I've beat them in and I've pressed them in properly. I don't know about the little 1/2 ton ones by the HD units are a bear to hammer them in.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-31-2014, 06:48 PM   #7
CC69Rat
CC69Rat's Avatar
Most of the auto parts stores have the free loan - a - tool option too. I agree, no way I'd pound them in with a hammer. Just me.. As others have suggested I'd locate a press.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-31-2014, 10:22 PM   #8
haminator
haminator's Avatar
Remember there's always more than one way to skin a cat. What ever works, works. I have a press but before I did a BFH did a lot of that kind of work. Heck I haven't used a pickle fork in years.
haminator is offline   Reply With Quote
Old 05-31-2014, 10:30 PM   #9
Aruba1
High quality ball joint press did not work for me. I ended up popping it off with a HF 4lb drilling hammer and a 21mm (i think) closed end wrench to get it a good hit. After 3rd time it came flying out.
Aruba1 is offline   Reply With Quote
Old 05-31-2014, 11:17 PM   #10
elimontfort
elimontfort's Avatar
http://lasvegas.craigslist.org/tls/4440770729.html
Pretty close to you I think. I have the same press and used it when I did my disc brake conversion. It's a good tool to have and at 80 bucks its a steal. Don't use a hammer man.
elimontfort is offline   Reply With Quote
Old 06-01-2014, 02:00 AM   #11
frank69
Give me a call, then just bring them over and I will help u put them in. Frank 702-285-3912
frank69 is offline   Reply With Quote
Old 06-01-2014, 06:05 AM   #12
hamjet
hamjet's Avatar
By the time you go to the store to rent one or pull it out of your storage cabinet or where ever you would keep it, ( because its something you'll use maybe twice in your life time) I'd have it in and out, and maybe I am stuck on a farm..
Thanks, Joe..
Old 06-01-2014, 03:01 PM   #13
davepl
davepl's Avatar
Looking above I see it's guys with half-tons that are saying it's easy and the guys with HD units that are saying it's hard.
I've done B-body car ones that are as big as the C10s, and yeah, they're tiny and easy to install. It's the stupid monstrous ones that are hard. And they get even bigger: I'm using 1972 Longhorn (so 3/4 or 1-ton) and they're even bigger than the 1970 1-tons. It's like a 2.5" socket if you want to pound them in. Last guy I watched do it (proving it can, in fact, be done) took about an hour and he's in 60s, been doing it for decades.
Skinning a cat is easy, it's putting it back on that's hard, and that's what we're talking about.
Old 06-01-2014, 03:51 PM   #14
haminator
haminator's Avatar
A press is for sure easier but sometimes we do what we gotta do.
Old 06-01-2014, 07:04 PM   #15
motorcritter
motorcritter's Avatar
I picked up a used OTC press from a used tool place in Denver (Charlie's Used Tools- they're on E-Bay, too), for about a third if what a new one cost. My uncle (who started me in the 'motor trades' when I was a young lad) told me 'If you need a tool twice, buy it!' Yeah, I've got some stuff I haven't used in about 40-odd years, but by and large, he was right. The 'free tool' deals at the LAPS come in handy, too. Especially if you aren't working on a number of vehicles, at any given time, like I do.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 06-01-2014, 10:00 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
x2 i've beat them in for years, last time i rented a FREE press from the parts house and was in in minutes.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
