Old 05-31-2014, 07:18 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
i have some questions about my swap
I have a few questions...
1) if i am not mistaken the ecm (99 silverado 4.8l 4l60e) the ecm provides the ground for the fuel pump ground, I have not gotten a tune, but the ecm will not turn the fuel pump on, i manually provided a ground to the pin my ecm is using and it came on. so my wiring is good.
2) according to lt1 swap.com the pinout says the ecm can run up to two fans, those two pins on the ecm also are providing a ground if i am correct. How do I tune this function in? (i am not a tuner i just want to know so i can discuss it with my tuner hes never tuned a gm car, but he is an experienced tuner we will use hp tuners)
3) on lt1swap.com it says we can use a pin for a tow haul mode
A)is this something that can be used with a toggle switch to run a totally differnt tune (for example a 91 octane tune and a E85 tune for the other) or is it only capable of slight adjustments to shift points etc like the factory does
B) what would be required to tune this in
4) what do i need to do with the TCC pin on the ecm? i have put the newer brake swith that has 4 pins (i believe) the two pins for the brake lights and two other pins
5) the tach output pin, I have an older sun 8k tach, what do i need to do with the one pin that i have on the ecm?
I may have more questions... but im not by the truck so i dont remember anything else atm. thanks for any input
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 05-31-2014, 07:56 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: i have some questions about my swap
2) How do I tune this function in? (i am not a tuner i just want to know so i can discuss it with my tuner hes never tuned a gm car, but he is an experienced tuner we will use hp tuners)
there is a Fan1 and Fan2, he shouldn't have an problem locating them. I will say tho, I would be very cautious about having someone tune your car who hasn't dealt with the way GM handles tq management and similar. I had a very good local tuner do mine, and after sitting down with a an o.e.m tuning engineer, we found issues all over. You can make a car run decent on a crap tune and never be the wiser until it blows up.
Hart Rod and some others had a thread on this a little while back. If you dig back through the Lsx section they have a few pages on setting it up. The GenIII and GenIV handle it a little differently.
There is a thread called Conventional Tach on LS2 that gives the part # for a pullup resistor allowing the use of regular tach's
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-31-2014, 08:03 PM   #3
1970 C10 MJW
what was the issues you had with your tune? just curious
Old 05-31-2014, 11:22 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
While the tune functioned, there were certain areas and ways things were done that were incorrect (or less than ideal). For example, my injectors are 39lb/hr, but at LS rail pressure (58psi), that becomes closer to 45lbs. The tuner neglected to scale correctly, and instead pulled fuel other places when the tune was richer than expected. Little things like that can become very detrimental. On a stockish swap, they are less noticeable. The farther you push it, the more likely that "good enough" isn't.
Old 06-01-2014, 12:01 AM   #5
ls1nova71
ls1nova71's Avatar
The PCM provides 12v to the fuel pump relay. You need to rewire your relay.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-01-2014, 06:17 PM   #6
1970 C10 MJW
oh, i was not aware that it provide 12V ground.. what does it do as far as fan output? positive or ground?
Old 06-01-2014, 07:18 PM   #7
whitels1
whitels1's Avatar
http://ls1tech.com/forums/conversion...swap-faqs.html
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
