05-31-2014, 08:21 PM | #1 |
valve cover question?
my 64 has a 350 out of a 1975 ,i got some new valve covers for it was wondering does it matter where breather holes are located, right now has a pcv on drivers side towards the front and breather on pass. side closer to firewall,might be a dumb question just want it to be right and read the importance of crankcase ventilation
05-31-2014, 08:26 PM | #2 |
Cluster King
Re: valve cover question?
If I had the choice, I would leave it just like it is. The pcv on the drivers side front and the breather in the rear on the passenger side. I think having the breather(s) in the rear helps keep the oil mess down under the hood. Just my thoughts
The truth is, it does not matter. The engine does not care as long as both are in place.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
05-31-2014, 08:28 PM | #3 |
thanks, any preference on gaskets to use
05-31-2014, 08:41 PM | #4 |
Cluster King
It depends on the covers you are using. I like Fel-Pro products. They make a 5/32 valve cover gasket for a small block or a 7/32 thick gasket. I would use the thicker ones on tin covers and the thinner ones on cast aluminum. Hope this helps.
05-31-2014, 09:06 PM | #5 |
thanks again ,installing finned aluminum ones
05-31-2014, 11:26 PM | #6 |
Make sure there's a baffle under the pcv or you'll be pulling oil out of the cover.
06-01-2014, 12:04 AM | #7 |
Fabricate till you "puke"
2nd that The Moroso covers were not baffled on my 383, & she would smoke out the tail pipes under high vacumn. I popped an oil separator in the cover, the plugged the pcv into that...(solved the problem) Little bro, is running that engine on the track (Cordova), in his S-dime....she don't smoke? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-01-2014, 12:13 AM | #8 |
thanks for the info, one of the new covers has a rubber looking baffle in it its definitely not a grommet ,im i correct
06-01-2014, 12:44 AM | #9 |
Put that one to the rear,under the cover breather. The pc I talked about, went to the front....2/12 to 3" canister, popped in the cover....looked like something, that you would see on a Mopar? You can purchase the part & at any speed shop. it had a tube out 1 side, to hook a short pcs of line to....then plug the pcv into that?Ill see, if I can dig up a PN. Longhorn
06-01-2014, 12:46 AM | #10 |
Maybe but hard to tell without a pic. They do make baffle/grommets though. Like these sold in a pair. One for the pcv, one for the breather.
http://www.speedwaymotors.com/PCV-Gr...Caps,7332.html |
06-01-2014, 12:49 AM | #11 | |
Like this! http://www.speedwaymotors.com/Billet...alve,7184.html |
06-01-2014, 01:12 AM | #12 | |
06-02-2014, 10:44 AM | #13 |
got new covers installed put breather and pcv valve back how they were,installed pcv valve into cover that had a rubber looking baffle like pic in the link but pcv is alot smaller then baffle,do i need different pcv or rubber piece.before and after
06-02-2014, 11:12 AM | #14 |
It's your choice.
Bigger grommet or bigger pcv. Since rubber deteriorates over time I'd get a better fitting grommet. |
