Old 06-01-2014, 08:30 AM   #1
Gmc-76
Gmc-76's Avatar
Rally wheels & hub caps?
I have rally wheels on my 85, and I picked up a set of hub caps off of a 76. I would like to know if there is any way for these to be on a rally wheel, just held on with tape for mock up. I think it would look pretty cool..
Andrew
85 Sierra Classic c10, 305/350/2:73(86k original)
instagram: anabb_98
Gmc-76 is offline   Reply With Quote
Old 06-01-2014, 09:08 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Rally wheels & hub caps?
I like that idea also, but never could figure out a way to securely hold the hub caps on.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-01-2014, 09:16 AM   #3
Axle
Axle's Avatar
No easy way to do it. The caps use nubs that are part of the wheel stamping to hold them on.
The alternate way; hot rodder style, weld some nubs to your exisiting wheels if you really want to use them. [and by that I mean build up some weld in the appropriate places]
Alex.
Axle is offline   Reply With Quote
Old 06-01-2014, 09:41 AM   #4
bbbc10
Diggin The SquareLife
use vw bug hub cap clips like they do to mount caps on centerline smoothies
bbbc10 is offline   Reply With Quote
Old 06-01-2014, 02:56 PM   #5
Gmc-76
Gmc-76's Avatar
Where can I find a set of them? And how do the clips hold to the wheel?
Andrew
instagram: anabb_98
Old 06-01-2014, 02:57 PM   #6
Gmc-76
Gmc-76's Avatar
Alex.
I have a set of 8 lug steelies from a parts truck that have the Nuba like that for caps, could I cut them off and weld them to my rallies?
Andrew
instagram: anabb_98
Old 06-01-2014, 03:35 PM   #7
bbbc10
you have to drill and tap the wheel for them cause they are held on by screws
http://www.ebay.com/itm/VW-WHEEL-COV...ec4f11&vxp=mtr
Old 06-01-2014, 04:00 PM   #8
Gmc-76
Gmc-76's Avatar
Thanks! I will order them tonight and will post pics of the end results.
Andrew
instagram: anabb_98
Old 06-02-2014, 04:34 PM   #9
Varietydiner
Varietydiner's Avatar
Why not just get some early rims?
Just got my 77's 6js banded to 10"
Fronts being done this week
Varietydiner is offline   Reply With Quote
Old 06-03-2014, 09:44 AM   #10
bnoon
Or you can order 15x10 plain steel wheels from Summit Racing http://m.summitracing.com/parts/wvi-62-5005042
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 06-03-2014, 10:30 AM   #11
Gmc-76
Gmc-76's Avatar
I need to go back to the pick an pull and find a set, are the backspacing the same? width?
Andrew
instagram: anabb_98
Old 06-03-2014, 12:42 PM   #12
Varietydiner
I assume the backspace of the early standard rims is the same as rallys(there are enough threads on here if you search) I just had the guy add 4" extra dish
Old 06-07-2014, 11:59 AM   #13
Axle
Axle's Avatar
No. You build up weld bead for the lip of the hubcap to hold onto.
Your rally wheels are sized differently from a stock steelie, probably will only need a small bead to hold onto the cap. I'm also wondering if those vw clips will work with the stock rally given the different shape of the dish.
Alex.
Old 06-07-2014, 02:20 PM   #14
805stickies
805stickies's Avatar
My buddy welded nuts to my wheels and it works great. No problems at all.
805stickies is offline   Reply With Quote
