Pertronix dist help
I could use some help with installing the Pertronix billet dist. in the new engine I am installing in my '68 C10.
I've already installed a Jeg's starter because I discovered the 283 starter I took off was not compatable with the 350 crate engine. I taped up the wire going to the "R" terminal on the solenoid. Now my question as to the new dist. can I wire it up to the coil as shown or do I need to wire it up differently because of the resistance or ballast wire as stated in the directions? Thanks! |
![]() ![]() Join Date: Sep 2008
Re: Pertronix dist help
I have five Pertronix, all wired to the coil. I know the manufacturer has a reason for bypassing the resistor wire, but for my needs, I haven't found a problem.
When I did the first one, I checked for voltage through the resistor, and it met Pertronix specs so I wired to the coil. If your battery gets a little low the Pertronix will not function. If nothing else, wire it though the coil and resistor wire, and if you have a problem, do it their way.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
I have installed a few & always follow the directions that come with it.
One of the First
![]() Join Date: Jan 2000
You need a full 12 VDC. Existing resistor wire only give's you 6/7 VDC.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Let us know how this turns out.
I will update. Thanks for the responses
Just an update I ran a new wire from the fuse box to the coil.
So far so good but I couldn't finish breaking in the cam because of a leak at the bottom trans line at the radiator. |
