Old 06-01-2014, 12:09 PM   #1
pwdcougar
pwdcougar's Avatar
Suburban crossmembers and body supports
I need to replace the crossmember on my 70 K10 4 speed burb and a few of the body mounts.
Is the K10 4 speed crossmember the same as a 2wd 4 speed burb crossmember?
How about the cab/body mounts?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 06-02-2014, 01:25 AM   #2
vectorit
What?
vectorit's Avatar
Re: Suburban crossmembers and body supports
I am not certain, but I'd be willing to try the cross member. Since I did have a '70 k10 at one time, and the trans cross member looked identical to what is in my K20 burb.
The body mounts... If you were cutting them off of a donor frame, and then planning to install them on your burb. I would say they are the same, since I used a mix of K5 and PU body mount bushings back when no one was making body mounts for a burb.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-02-2014, 08:37 AM   #3
pwdcougar
pwdcougar's Avatar
I'll have to crawl underneath my 68 2wd and see if they look anything alike.
