seatbelt mount
Where does the seatbelt mount on the drivers side.
Check out my build: 1972 LQ4 Swap http://67-72chevytrucks.com/vboard/s...=1#post5427693 |
Re: seatbelt mount
Should be right in here some place.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Re: seatbelt mount
Looks like I need to drill and tap unless I am missing something else.
Re: seatbelt mount
heres mine, there should be a welded nut
Re: seatbelt mount
The rockers got replaced so im wondering if the nut went with the old
![]() Join Date: Nov 2007
Re: seatbelt mount
asole is fairly correct. If you go to my build thread, another used did a measurement for me as to where its to be. Should be a little further forward, around 2.25-2.50 from the back wall.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
Re: seatbelt mount
that looks like fiberglass under that paint????
Re: seatbelt mount
looks like fiberglass to me also, You might be looking at a can of worms soon.
Re: seatbelt mount
Ill take a look when I get home. Ill see if its a little farther forward. Pretty sure theres no fiber glass in it. Thanks everyone.
Re: seatbelt mount
I found these same two plug welds on both sides right around 4 inches back from the wall. Id imagine these are what im looking for any my body guy didnt know what it was?
Re: seatbelt mount
Re: seatbelt mount
Its a terrible picture but the red lead is pointing at the plug weld.
#13 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: seatbelt mount
Yes - maybe he can fix it for you so you can have seat belts?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#14 |
Re: seatbelt mount
my seat belt hole is 2 3/4" from wall and I have a weld plug dimple just under 7" from the wall in original floor.
Grillzy |
#15 |
Re: seatbelt mount
Thanks for the help. I ended up shining a flashlight through the drain hole in the rocker to find the nut inside. Then I drilles through the top to get to it.
#16 |
Re: seatbelt mount
Is the passenger side in about the same spot? Im not having any luck locating it.
#17 |
Re: seatbelt mount
I dont have a pic for you right now but the passenger side should be on the vertical wall about 4"-5" down and maybe 1" - 2" or so away from B pillar. I just covered mine up with carpet and havent install my seat belt yet.
#18 |
Re: seatbelt mount
again, solde is to the front of the line.
mounts totally different. |
#19 |
Re: seatbelt mount
Thats right for 70-72 but and fyi I think 69 is on the actual bed floor. I know you have a 72 but just putting this out there. Asolde, you still have your 69 and is your pass seat belt mounted there?
#20 |
Re: seatbelt mount
Thanks. I ended up scanning through a bunch of build threads and found some pics of it on the wall and then found it. I didnt realize that there was a passenger side specific belt that I have to look for now for aesthetic purposes. Thanks again.
#21 |
Re: seatbelt mount
Yes I have a 69 too and the passenger side seat belt is mounted to the bed next to B pillar.
