Old 06-01-2014, 04:54 PM   #1
psuedopimp
psuedopimp's Avatar
Front drum removal
1970 k5 drums all around
Got the hub lock out. Two spindle nuts, a spring and the front bearing. Thought for sure the drum would pop off by now. I am missing a spring clip somewhere?
psuedopimp is offline   Reply With Quote
Old 06-01-2014, 09:17 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: Front drum removal
Sounds like you need to adjust the shoes in. Can you feel the shoes grabbing in the drums?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-01-2014, 09:20 PM   #3
psuedopimp
psuedopimp's Avatar
Yep that is what it was. Just afraid to pull on it. I actually yanked until I broke the shoes loose. Not a big deal since I'm replaceing them anyway. But. How do you adjust the shoes in??
Old 06-01-2014, 09:34 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Should be a slot in the backing plate near the bottom. With it all apart you should be able to see where you could slide in a screwdriver and turn the adjuster wheel in the opposite direction and loosen the shoes.
