Old 08-02-2003, 12:34 AM   #1
kwmech
finishing bed wood
Allright I am getting ready to do the bed on my 68 longhorn and I have been talking to various people on what would be best to put on the oak that is going to last without continuos upkeep.
Who has first hand experience and what works and what doesn't?
Old 08-02-2003, 04:05 AM   #2
OhioDan
OhioDan's Avatar
I used a "Marine Grade" polyurethane. It had a hi UV rating to protect it from the sun. It's for a boat. ( so much for the water problem ) I've put about 6-7 coats on it as of right now. Wet sanding between each coat with 400 grit paper. It's now ready for the final sanding and polishing.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 08-02-2003, 11:37 AM   #3
kwmech
Looks nice, but how user friendly is that going to be? Do you plan on showing or using your truck? Reason I ask is because years ago I did the bed on a show truck with varnish and it was one of the biggest mistakes I ever made.
Old 08-02-2003, 12:17 PM   #4
palallin
What was the original finish? I will actually be using mine for hauling, and that slick-as-glass surface would not be good. Besides, even marine anti-IV varnish isn't all it's cracked up to be: you should see the transom of my boat.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-02-2003, 01:14 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
GM just sprayed automotive paint on the boards to match the color of the truck. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-02-2003, 01:57 PM   #6
kwmech
You are correct and of course for max protection a good quality oil base exterior paint would be the best. But I want to [like every one else] customize. I have heard that there are some good quality oils out there, have been told by some old school finish carpenters to use an exterior type oil such as a marine oil. I may go this route. I figure if I don't like it I can still apply an oil base poly urethane over the top of it.
Old 08-02-2003, 03:35 PM   #7
Brewski*
Brewski*'s Avatar
Alright Here Goes...
If I were to put a wood bed on my truck (and I am going to). I will make sure the wood is dead hard: Maple, Walnut, or even Bamboo. Yes, I said bamboo. Harder than Maple and only slightly softer than Walnut and stunningly beautiful. Big plus with the Bamboo is that it is a grass and does not absorbe water after it dies. Finish on any of the above boards would be the ROCK hard Hammer Tested Tough "Glisten PC" from POR. I have painted carbon fiber speedskating boots with it for over a year now and when dry (4 days) it is rock hard and is tougher than any epoxy clear coat that I have seen (and I have seen them ALL). I am going to start doing several dash parts in Carbon and hope to have bed strips custom made in Bamboo before the Christmas holiday season. If all goes as planned they will be available for shipment in the spring.
Brewski* is offline   Reply With Quote
Old 08-02-2003, 09:01 PM   #8
71Derelict
The finish in the previos post by brewski sounds pretty promising. If you are going to use any type of oil to finish the wood bed just realize that you will have to re-apply it at least 1 to 2 times per year. Just my .02
71 C/10 Short Wide
2/3 drop, 383/350/3.08 posi
in various states of repair
growing into 4/5 drop 383/700R4
71Derelict is offline   Reply With Quote
Old 08-03-2003, 12:06 PM   #9
kwmech
I'm thinking that reapplying once or even twice a year would not be that big of a deal. With a 2'' wide brush would take about what 1/2 hour to 45 minutes? and then just walk away, don't have to worry about a lot of sanding or prep. just a thought. Anyone else?
Old 08-03-2003, 10:49 PM   #10
Benrs86
Benrs86's Avatar
dude i put oak in my daily driver. huge mistake. had to cover it to keep it nice so you cant see it unless the covers up and now i cant throw anything in the back...the wood and everythingn added up to about 800 bones. it was bruce horkey though
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 08-03-2003, 11:18 PM   #11
mtdave2
newly minted old timer
mtdave2's Avatar
i think they were painted from the factory. my longhorn had paint on the wood and it had a camper on it from day one.. ????
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
