Old 06-01-2014, 06:00 PM   #1
70chevlow
truck starts than dies
Having trouble with my truck went to start yesterday and it fires up but as soon as you let go of key it dies starter has to be constantly going for it to run. Where do i start i replaced the ignition switch no luck with that everything else appears to be fine no dissconected wires eveb ran fine the night before any help will be appreciated. Its a freshly rebuilt 350 that was running fine thw night before.
70chevlow is offline   Reply With Quote
Old 06-01-2014, 07:45 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: truck starts than dies
Is it points? If so you are getting power to the dizzy through the starter while cranking and the ballast resistor is not giving it the lower voltage for your run signal.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 06-01-2014, 07:48 PM   #3
Avitech
Avitech's Avatar
what he said.
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline   Reply With Quote
Old 06-01-2014, 09:10 PM   #4
70chevlow
Nevermind stupid me i had the steering column dropped and it caught my ignition wire by the fuse block.
