Old 06-02-2014, 09:37 AM   #1
smartass12
smartass12's Avatar
Water pump help
So i was topping off my coolant system and when doing so water (a lot) came out of the weep hole in the water pump. Is it safe to assume in need to replace it? (2001 5.3)
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 06-02-2014, 09:43 AM   #2
ERASER5
ERASER5's Avatar
Re: Water pump help
Oh yea! Water coming out ofthe weep hole is bad sign.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-03-2014, 10:25 AM   #3
smartass12
smartass12's Avatar
Re: Water pump help
great.. hopefully there isnt a bigger issue.
on a side note. any reason not to replace it with the camaro water pump (same spacing) just in case i change to an ls6 style intake
Old 06-03-2014, 01:28 PM   #4
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Re: Water pump help
LS water pumps are notorious for going out, so you can prob rest easy knowing the pump is the problem. The water pump spacers are needed to swap to the ls1 style pump if I remember right. I went electric so I didn't really bother with all the spacing and such. I don't think the spacers are too expensive though and if you have a serious interest in swapping the intake later on, then why do it more than once right?
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 06-04-2014, 11:36 AM   #5
littlevictories
Re: Water pump help
yep, you'll need spacer if you wanna use the f-body pump with the f-body pulley
someone was telling me you can press off the f body pulley and press on the truck pulley and that fixes it. probably gonna give that a shot myself eventually.
littlevictories is offline   Reply With Quote
Old 06-04-2014, 11:52 AM   #6
RocketChevy56
Re: Water pump help
if you were to use the gen 5 camaro water pump, would you have the clearance for the car intakes? I know those pumps have the same spacing as the truck acc. and move the inlet to the driver side but are they low profile enough?
Old 06-04-2014, 03:47 PM   #7
dayj1
Re: Water pump help
Yes.
dayj1 is offline   Reply With Quote
