Old 06-02-2014, 11:57 AM   #1
DMO
Installing Locar floor shifter?
I pulled the old carpet out of the cab expecting to find a bolt on section of the cab over the transmission that could be removed. Just my luck the center section is not bolted on.
My plan is the Locar shifter directly mounted to a 700r4 trans. Obviously I have to cut the opening in the floor. Do any of you have suggestions on the best way to do this? Thx
DMO is offline   Reply With Quote
Old 06-02-2014, 12:38 PM   #2
Re: Installing Locar floor shifter?
When I did my manual speed to the floor, I used my dremel tool (and a few discs). At the time I didn't have a bigger cutoff tool, but even now I think I would use the dremel for the better control of the cut.
Old 06-02-2014, 12:53 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I use a Dremel tool for almost all of my cutting, even on solid steel up to 1/4" thick. But instead of the little "break easy" discs, I use these EZ Lock style with a locking hub in the middle that looks like the Batman emblem. I mostly use the "THIN CUT" versions rather than the ones marked METAL. They are about half as thick and really make precise cuts.
The hub will tear out if too much deflection is introduced, but they never fly apart. They just spin around the hub when broken, making for a simple change to a new cutting wheel.
http://www.dremel.com/en-us/Accessor...Cut-off+Wheels
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-02-2014, 01:21 PM   #4
PGSigns
PGSigns's Avatar
When I did my lokar in the 66 I used a 4 1/2" hole saw. Drilled a small hole in the floor that I thought was close and went under the truck and checked to see where it was and adjusted the new center for the 4 1/2" hole off of that. Worked like a charm.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-02-2014, 01:31 PM   #5
DMO
I like the hole saw idea! I will give that a shot. I would love to find the portion of the cab floor that is normally bolted on so I could cut in the normal opening and have a removable cover. I have been looking at LMC and other sites but I have had no luck. Any idea where I might be able to pick something like this up?
Thanks for your help!
Old 06-02-2014, 02:19 PM   #6
1963c-10
1963c-10's Avatar
You'll need to find a 60-63 cab to get a bolt in trans cover.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-02-2014, 02:22 PM   #7
tincan1966
tincan1966's Avatar
The only removeable floor center or "hump" is for the 4 spd and will be a high hump. The automatics and 3 speed humps are not normally removable, from what I've seen.
tincan1966 is offline   Reply With Quote
Old 06-02-2014, 02:25 PM   #8
oem4me
Would the factory hole in the four speed bolt-in cover be in the correct place for that trans?
Old 06-02-2014, 04:37 PM   #9
forestb
forestb's Avatar
Not to be argumentative just clarifying. I have a 62 with a small hump that bolts in and I have seen a gmc at the junk yard with one also. It really messed me up when I ordered a carpet from Brothers trucks and there catalog said that only high humps bolt in. I did not know what a high hump looked like so I ordered carpet for a high hump. Big mistake.
forestb is offline   Reply With Quote
Old 06-02-2014, 06:18 PM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Installing Locar floor shifter?
http://www.jegs.com/webapp/wcs/store...sion+Shifters+
http://www.google.com/custom?domains...D%3A1%3B&hl=en
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
