master cylinder fluid level
I was just routinely checking things and opened up the brake master cylinder resivor and noticed a large discrepancy between the two levels. It appears that the rear brake resivor is lower than the front. I checked under the truck front and back and behind the wheels and the lines and cant find a leak.
I included a pic. I cant find a fill level mark on the master cylinder or in it so how do I know how much I should add? Should I fill it to the top? paul |
Re: master cylinder fluid level
I would fill it to about an inch from the top and monitor closely for a awhile. The fluid went somewhere. Maybe the brakes were not bled properly last time and they gravity bled them selves.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Apr 2013
Well there is more line to the rear so you fluid is just in the lines probably....if you didnt know what the fill level was before you could be chasing a ghost looking for a leak when there isnt one.. get under ur truck and check the lines..if you dont see any oil stains coming from the lines....then your not leaking...just fill it again and watch it more closely...this how you become one with your c10..you know all the ends and out...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
I filled it. Ill watch it closely. Check every few hundred mikes for a while. I cant find any leaks. Brakes work fine, at least for drum brakes.
going to do the swap soon I hope. Maybe we will discover a leak while doing that. thanks for all the info. This forum is amazing. paul |
The wheel cylinders could be leaking inside of your brake drums. It wouldn't hurt to pull the drums and insect them.
while your at it pulling the brake drums and seeing if you have any brake shoes left to stop in case
#7 | |
I found a small leak from a wheel cylinder that I didn't see on the outside.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
![]() Join Date: Feb 2014
The brake fluid may be burnt in the combustion chambers of the motor.
Huh?
If there are no visible external leaks to explain the loss of fluid and there is a confirmed decrease in the master cylinder level above and beyond normal wear/adjustment of the brake shoes, the most likely cause is a leaking master cylinder. This fluid will leak into the cab/ firewall or it can be sucked up by engine vacuum if the power vac assist is bad. Once vacuumed up off to the cylinders to be burnt. This can be hard to see and find
Wow, never heard of that. Seems like the truck would run like warmed up donkey crap.
Truck runs great! I doubt its burning brake fluid. It does however use massive amounts of gas even when not under a load. Steady 60 on the freeway, no head wind, maybe 10mpg! But I still love my chevy!
#13 |
![]() Join Date: May 2013
lossen the 2 nuts that hold the master to the booster , pull the master forwaed slightly , if it is wet behind you need to replce the master , and probably the booster also , most times they will not leek into the cab or firewall as the booster catches and contains the fluid , if its not wet , put the 2 nuts back on , takes all of 10 minuets to check
the fluid should be an 1/8 inch for the lid of your master
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#14 |
Wise advise 67 Chevelle. This phenomonia usually happens very slowly, un-noticeable at first. But like most things it will worsen at variable rates. At first you may not notice any engine difficulties. But if the leak is large it will definately affect performance, idle, exhaust will be white with tons of smoke in a massive leak or if the vacuum gets a big snort of brake fluid because the angle of the master cylinder booster changes with the truck.
#15 |
Thanks for the info. When I loosen those two bolts and pull forward will I effect the brake line? I dont want to have to bleed the brakes.
#16 |
The procedure 67 Chevelle described should not introduce air into the closed system. The lines have a little "wiggle" room. Good luck, Bruce
#17 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
The scenario 67 Chevelle described actually happened to me...I didn't realize the fluid was leaking directly into the hydrovac unit until it failed while I was standing on the brake at a drive through window. The brake pedal suddenly went to the floor and no more power brakes!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
