06-02-2014, 01:20 PM | #1 |
Ignition won't turn off engine, harness swap 72
350 3 on tree
Swapped out under dash harness with a gauge harness that I believe came from an automatic. didn't change engine harness. Won't turn off with key, have to disconnect at alternator to kill engine. What wire is causing this?
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
06-02-2014, 01:25 PM | #2 |
Re: Ignition won't turn off engine, harness swap 72
I figured it out had the engine harness side going to a none ignition lead on fuse block. Moved to unfused ignition slot on fuse block .
Thanks!
