Old 06-02-2014, 01:28 PM   #1
72blaz
72blaz's Avatar
Paintable Instrument Panels?
I'm inching closer to painting my blazer and I am not a fan of the plastic instrument panel
that the factory installed....Since I'm doing a little of my own modding I was wondering what options I have for an instrument panel I can put on and paint the body color... Right now all I see is carriage works...which looks like might be fine..but they show two options at Summit..yet I can't figure out the difference...other than price...so any suggestions?... does someone else make a metal dash panel?... any help would be greatly apprecitated.
1972 Chevy Blazer
Check out my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=560741
72blaz is offline   Reply With Quote
Old 06-09-2014, 09:48 PM   #2
SamMargritz00
SamMargritz00's Avatar
Re: Paintable Instrument Panels?
we had a metal shop cut a piece of metal plate to bolt over the original and cut the holes out then painted it to match the dash. Theres pictures on my build thread
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 06-10-2014, 03:53 AM   #3
skorpioskorpio
I've seen glove box doors used as insturment panel blanks on here. Same shape, just cut holes and a little trimming. There is also a member making milled aluminum panels though both these options are generally used with aftermarket gauges.
skorpioskorpio is offline   Reply With Quote
Old 06-12-2014, 12:02 AM   #4
Jdubs71
Jdubs71's Avatar
You can buy a stainless or aluminum dash with the holes cut out for your own custom autometer or similar type gauges. I have a brushed aluminum 6 hole dash hiding in a box somewhere. Ive seen several different designs. Search the other boards and I'm sure you'll find something.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 06-12-2014, 09:25 AM   #5
72blaz
72blaz's Avatar
thanks for the advice!.. I will be using aftermarket gauges..so I guess carraige works will work fine.. although I will try to do a quick search before I pull the trigger today.. Thanks again.. I'll hopefully have some pics soon..but we all know how long soon is when restoring a blazer.
1972 Chevy Blazer
Check out my build:
Old 06-12-2014, 09:50 AM   #6
Jdubs71
Jdubs71's Avatar
Here is the one I have. Its made by a company called no limit out of CA.
My build thread
Old 06-12-2014, 10:03 AM   #7
72blaz
72blaz's Avatar
that sharp!.. my only fear is that I'm painting my truck silver... so I don't want to have to that large of an area (dash panel) so close to the silver color..... smaller like badges ..etc.. will look sharp...but that's alot of square feet.
1972 Chevy Blazer
Check out my build:
Old 06-12-2014, 10:05 AM   #8
72blaz
72blaz's Avatar
I'm really just trying to find a very blah... panel.. that will fade into the body color and pop with black background aftermarket gauges..
1972 Chevy Blazer
Check out my build:
Old 06-12-2014, 11:12 PM   #9
AirSpeed
AirSpeed's Avatar
I painted my plastic one, been good for years
AirSpeed is offline   Reply With Quote
