Old 06-02-2014, 02:17 PM   #1
70chevlow
c20 fuse block help
I seem to keep having trouble with this truck my question this time is about the fuse block. Both unfused ignition terminals are hot all the time what should i check for or how do i correct this problem i have to plug the ignition wire into a different terminal to get the truck to turn off when i turn the key.
70chevlow is offline   Reply With Quote
Old 06-02-2014, 03:06 PM   #2
long67
long67's Avatar
Re: c20 fuse block help
You should have a place on the box marked ign. to plug into for that.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 06-02-2014, 03:31 PM   #3
70chevlow
I see where its marked ignition but the problem is the terminals are hot all the time they dont cut power when the key is in the off position
Old 06-02-2014, 07:48 PM   #4
JimKshortstep4x4
I would check the back of the ignition swtch and the wiring since the terminals on the fuse panel get their power from the ignition switch.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
