06-02-2014, 06:18 PM | #1 |
Dash lites
How do the dash lites come out of a 64. Do they come out of the back side of the dash,or came I take the dash bezel off and pull then out? Does any one sell brighter ones?
06-02-2014, 07:15 PM | #2 |
Re: Dash lites
They come out from the back and they just pull out. I have found that if I take the plug and push left /right / up or down it will smap out. I do not know if anyone makes a brighter bulb. Good Luck.
06-02-2014, 07:18 PM | #3 |
Re: Dash lites
I installed LEDs in mine and they look very nice. They are a whiter light and I got them on eBay
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 06-02-2014 at 07:20 PM. Reason: add |
06-02-2014, 07:40 PM | #4 |
Re: Dash lites
Do you have a eBay link for the lights you got. Thanks evan396
06-02-2014, 07:55 PM | #5 |
Re: Dash lites
The downside of installing the LED's is you loose being able to dim them, BUT since the most common complaint or reason to upgrade is because they are too dim...problem most likely takes care of itself. You can also freshen up the inside of the cluster housing with bright white paint and get rid of the green glow.
06-02-2014, 07:59 PM | #6 |
Re: Dash lites
not my pics but great idea
http://i618.photobucket.com/albums/t...pse4006e54.jpg http://i618.photobucket.com/albums/t...psfe6b69bb.jpg http://i618.photobucket.com/albums/t...ps4ef3afb3.jpg
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
06-02-2014, 08:00 PM | #7 |
Re: Dash lites
it was a year ago but look under 194 led bulb i think
06-02-2014, 08:34 PM | #8 |
Re: Dash lites
I may try the aluminum tape. Is there any thing I could paint inside to make the lites brighter?
06-02-2014, 09:51 PM | #9 |
Re: Dash lites
I haven't done it yet, but many guys upgrade from the 194 bulbs to the 168's. They're about 50% brighter.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
06-02-2014, 11:55 PM | #10 |
Re: Dash lites
Very simply put, all you have to do is run a dedicated ground all the way to your dashboard cluster, then, make sure you have a good connection between each socket and that ground, via the hole the socket plugs into. I have done this, and my dashboard is extremely bright. No problem seeing it at all.
If you really want better, brighter lights, check out M.A.D. Electrical's website, and upgrade your grounding and power systems. |
