Old 06-02-2014, 08:29 PM   #1
72MARIO
72MARIO's Avatar
Bagged and 1 piece driveshaft ?
I have a 1968 Suburban with bags in place of rear coils no notch. I am going to install a Gearvendors overdrive next week and I am wondering if I can use a 1 piece shaft. The gear vendors adds 14" to the transmission length .
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-02-2014, 08:38 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bagged and 1 piece driveshaft ?
Sure.
As long as it will pass thru the trailing arm crossmember.
Cycle the suspension to verify it.
Keith
Convert to disc brakes.
Old 06-02-2014, 09:11 PM   #3
72MARIO
72MARIO's Avatar
Would flipping the trailing arm mounts on the cross member help with clearance of worsen the problem ?
2005 TAHOE DD
Old 06-03-2014, 04:47 PM   #4
SCOTI
SCOTI's Avatar
My bet would be 'make it worse'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
