06-02-2014, 09:26 PM | #1 |
Need info on older 4wd front setup - 1968 Suburban
This is the only older type 4wd unit I have and do not have a good manual showing the older setup. Starting to leak at the wheel/hub/ball point. If you guys can point me to a previous thread/review/pics/diagram that demos disassembly, seal setup and reassembly I will be fine. Seems better to review before I start turning nuts, etc. Any thoughts?
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
06-04-2014, 11:53 AM | #2 |
Re: Need info on older 4wd front setup - 1968 Suburban
if you have the stock axle dana44 closed knuckle you can still buy the knuckle seals and plates. now the lube for the ball knuckle is hard to find. john deer makes something similar.
1961 chevy K10 my build is------------61K10 build |
06-04-2014, 12:37 PM | #3 |
Wide n'Low
Take a peek here for most everything you need
http://www2.dana.com/expertforms/depdf.aspx?prod=AXL
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
06-04-2014, 11:29 PM | #4 |
Thanks guys - very helpful. Ridgeback sent me a PM with a good manual as well. Thanks to all.
06-10-2014, 09:46 PM | #5 |
John Deere corn head grease
