06-02-2014, 09:42 PM | #1 |
Old Skool Club
Blazer tank in SWB
I know that this is an old school tank relocation thing, but I wonder if it is still the best tank to use on a 4-inch lowered SWB truck. '69 Camaro tanks also work and there are aftermarket tanks, in plastic or metal. My budget won't allow for the full-on custom route. So, I'm thinking that a metal Blazer tank kit is a good fit.
Anyone got any comments or thoughts? Thanks.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-02-2014, 10:22 PM | #2 |
Moderator
Re: Blazer tank in SWB
I put a blazer tank under my blue 72. I won't ever do it again. Trying to make a filler work out was a real pain. I'm leaving all my tanks in the cab from now on. Just my opinion.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-03-2014, 09:50 AM | #3 |
Blazer tank "kit" from LMC, $200 and you get to cut you about 2" out of your bed cross sill for the width of the frame to get it flush against the frame. Not to mention all the other complaints I have read about them.
Boyd welding tank, Standard NON-EFI, bed fill. $349. Drill 4- .5" holes in the aluminum tank mounting flange and install 4 bolts ( in existing holes in the frame).http://www.fueltankparts.com/67-72-s...-bed-fill.html Personally I would spend the extra for the Boyd tank. I see lots of people buy a blazer or other kit and have to mod all kinds of parts and the frame to make it work.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-03-2014, 09:59 AM | #4 |
Carpe manana
I'd leave the in-cab tank in place and use the $$ elsewhere on the build. If you do the swap, adding the fuel filler neck in a position similar to what GM did for the 1970 aux tank option may be the path of least resistance but upper trim could interfere with the bedside outer hole location.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-03-2014, 11:06 AM | #5 |
I have "Blazer" tank in rear of my '67. Kit came from Brothers. My rear is 7" down. Ya, as others have said there needs to be some mods made to make it work and fit correctly. Seems like I gotta mod a lot of stuff anyways so didn't seem like big deal to me.
06-03-2014, 01:10 PM | #6 |
I got a blazer tank....... didn't have to cut the frame but did have to cut a hunk out of one of the rear bed supports. But I'm running my filler hose up into bed, the tank lmc makes I don't think you have to cut anything just a hole in the bed floor cause the tank is a few gallons less then the blazer tank and the filler sticks straight up in the middle of the tank.
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
06-03-2014, 01:24 PM | #7 |
Old Skool Club
Okay, I hear you all loud and clear. So, it seems I'd be better off keeping my OEM tank (which is in good shape). I would like to do away with the odor of gasoline, tho.
As I recall removing the OEM tank, I can't think of anything except the sending unit gasket that would be a source of an odor. So, I'll check it out some more. Thanks for the feedback.
06-03-2014, 01:55 PM | #8 |
If the tank is not leaking the odor is coming from the rubber hoses connecting the hard lines or sending unit o-ring. Replace those and you will not have any odor. There are a few hoses that connect the hard lines to the sender, at least on mine a rubber hose from the neck to the tank (maybe part of the venting?). Also check the condition of the rubber connecting the hard lines under the cab and the tank neck to cab grommet. I see no logical reason to move the tank from the cab unless maybe your doing an LS swap. IMHO, there are a lot better mods to use that cash on.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-03-2014, 06:35 PM | #9 |
The blazer tank can be adapted w/ blazer straps, the biggest pain is the filler neck. Neither my 67 or 68 will drive down the road again w/ a gas bomb in the cab!!!
There's a thread here about someone making a nifty filler neck that hides behind one of the tail lights. He's had other things going on, I need to check on that again... |
06-03-2014, 06:48 PM | #10 | |
06-03-2014, 07:13 PM | #11 |
Carpe manana
I looked at a locally advertised LWB Cheyenne Super 72 K10 last night. The guy told me of a head on collision he had in a 70 LWB 4wd truck that sent his truck over the top of the other car and onto its side in a ditch. I asked him if the tank leaked - he looked at me a little puzzled and said "No" - it was driver side down.
06-03-2014, 07:31 PM | #12 |
Project Junkie! Fishing Poor!!
I vote for the Blazer tank, however it is not for safety concerns. You will hear all kinds of people report problems like filling the tank, fitting a gas filler door etc. It is a customization on your truck, and customizing isn't always easy, but this conversion is. You can go to my website and there is a big write up about how to do it in my how to section. I have done it, and as long as your filler hose heads down hill the whole way from the filler to the tank it will fill up just fine. Also don't forget to use all of the vents in the tank, do not plug any. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
