Old 06-02-2014, 09:58 PM   #1
K10Dream69
K10Dream69's Avatar
Fuel Filler will not Fill. Boyd's Rear Fuel Cell. Need Advice plz
I'm still messing around with the restoration of her but I decided to take her out for a spin. Trying to get more motivation to finish her.
I wanted to try out my fuel filler that I designed for my Boyd's Fuel Cell (Side Fill)
I bought a vented gas cap too.
The gas pump immediately clicks and won't fill at all.
It's really frustrating cause I have a lot of time involved with this!!
I'm not sure what the problem is so I'm hoping someone has an idea??
I'm assuming it's the angle of the hose - I didn't want to cut a bigger hole in the bed
Any input is appreciated
Here's a couple pictures of the setup.
K10Dream69 is offline   Reply With Quote
Old 06-02-2014, 10:05 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Fuel Filler will not Fill. Boyd's Rear Fuel Cell. Need Advice plz
you have too much of a droop in the line you have created a pee trap you need to make it slope to the tank more without the dip in the hose maybe use a elbow where it comes out the floor
69chevytrucker is offline   Reply With Quote
Old 06-02-2014, 10:06 PM   #3
geezer#99
geezer#99's Avatar
It won't burp the air out with that drop in it. Try a 45* elbow up as high as you can with a slope into the tank.
Old 06-02-2014, 10:09 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
It is only a guess but I would say based off of your photo that your fill hose is working like a p-trap on a sink drain. It looks like you may be able to shorten the hose some. You want the tank inlet to be the lowest point of the filler tube/hose.
If gas is sitting low in the hose, it will not let it vent properly.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-02-2014, 11:52 PM   #5
muckyp
muckyp's Avatar
I have a very similar setup to yours and had the same problem initially. I ended up cutting holes in the support member (see pic, sorry its sideways) to eliminate the droop in the hose and also ended up needing a larger vent tube. Hope this helps, good luck.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 06-02-2014, 11:58 PM   #6
71swb4x4
71swb4x4's Avatar
I agree with the others, you can't have a droop in your hose like that. You are not pumping fuel through that line, you are pouring it. It will not pour uphill.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-03-2014, 12:36 AM   #7
Ridgeclimber
I have a Boyd's side fill tank in my step side. I put a filler door on the inside of the box side. I went down to the exhaust shop and they bent me up a elbow out of 2 inch tubing. Then I just have two small pieces of fuel hose and some clamps to connect it. The tube is a straight shot into the filler elbow. Plus I also ran another hose from the roll over valve elbow up above the height of the gas cap.
Ridgeclimber is offline   Reply With Quote
Old 06-03-2014, 10:58 AM   #8
LSUMurse
LSUMurse's Avatar
Here's a link to some angled filler hoses at O'Reilly. I'm sure any parts house will have them, O'Reilly is just what popped up first.
http://www.oreillyauto.com/site/c/se...0065/C0075.oap
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 06-03-2014, 03:46 PM   #9
Fitz
A rubber 90 and a straight section of stainless or a stainless 90 and a short straight section of rubber or some other combination of tube and hose would work better than what you have. Clamps and ells are available at any autoparts store the stainless you can get from summit, Jegs, Burns etc. That's how I solved my rad hose problem and it does look better than ribbed hose.
Fitz is offline   Reply With Quote
Old 06-03-2014, 07:12 PM   #10
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
The biggest problem I see is that your vent line also dips with the filler neck. I would move the vent line higher so that fluid can't get trapped in it. The dip in the filler hose should not make a large difference as long as the vent line is large enough and free of obstructions.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-03-2014, 07:36 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Seen this problem many times before. It is your fill line. Shorten the hose. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-03-2014, 10:14 PM   #12
jondancer
Cut that hose and just use an aluminum elbow at the bend.
jondancer is offline   Reply With Quote
