Old 06-02-2014, 10:01 PM   #1
pritch
pritch's Avatar
I need to find a fuel filter like this:
With the 5/16" threads on each end. I want to eliminate as much rubber hose from the fuel system as possible, and since I'm making new fuel lines anyway, I figured something like this would be a good option. Any ideas where a guy could find one? I'm having no luck at all.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 06-02-2014, 10:13 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: I need to find a fuel filter like this:
some tractors use them i will get a part from work tomorrow
69chevytrucker is offline   Reply With Quote
Old 06-02-2014, 10:18 PM   #3
69chevytrucker
also here is a holley one
http://www.holley.com/230606ERL.asp
Old 06-02-2014, 10:25 PM   #4
69chevytrucker
this one
http://www.summitracing.com/int/part...f652/overview/
Old 06-03-2014, 12:11 AM   #5
Johnnyhotrod
I want to say 481 maybe? Standard fuel injection filter for 90s chevy?
Johnnyhotrod is offline   Reply With Quote
Old 06-03-2014, 12:30 AM   #6
allchevy58
allchevy58's Avatar
Same as my 87' Buick Park Avenue 3.8 L
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 06-03-2014, 01:29 AM   #7
Johnnyhotrod
Just verified... 95 chevy c1500 with 5.7... Can get this filter at any auto parts store...
Old 06-03-2014, 01:31 AM   #8
Johnnyhotrod
Not sure about the 5/16 threads... 5/16 fuel line = yes
Old 06-03-2014, 11:20 AM   #9
kwmech
Look at the application for a later model ford truck, carbureted 460 engine. They weren't very large though
Old 06-03-2014, 12:15 PM   #10
Old Truck Man
Old Truck Man's Avatar
Its a very good idea to try and eliminate as many rubber fuel lines as possible. especially between the fuel pump & carb.
Old Truck Man is offline   Reply With Quote
Old 06-03-2014, 01:06 PM   #11
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Looks just like the one on my 2002 Burb
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 06-03-2014, 07:22 PM   #12
mighty_mike015
While a 3/8 line (If I remember correctly) tube nut will thread into it, the flare will not seat and seal. These require an o-ring style fitting.
I am referencing Puraltor F33144, AC Delco GF652.
Fitting multiple GM vehicles.
mighty_mike015 is offline   Reply With Quote
Old 06-03-2014, 07:43 PM   #13
66pnl
66pnl's Avatar
I've hard-lined into those filters, I seem to remember using some sort of adapter fittings. ( This was several years ago, the details are a bit fuzzy )
66pnl is offline   Reply With Quote
Old 06-03-2014, 08:49 PM   #14
undertaker72
undertaker72's Avatar
napa auto parts have them , its just a inverted flare in line filter , instead of nipples a little more money , but a lot safer and a cleaner look
undertaker72 is offline   Reply With Quote
Old 06-03-2014, 10:23 PM   #15
pritch
pritch's Avatar
Excellent leads, guys! I'll check on some of these tomorrow.
Thanks, all
'68 Panel
'68 C-10
Ol' Green
Old 06-03-2014, 11:13 PM   #16
davepl
davepl's Avatar
Whatever you do don't give up and use one of those horrible glass ones.
A fuel-injection-era one might have the GM fuel disconnects. You can make those with the Mastercool set (though I do not have the EFI dies you'd need).
Next thing to consider is even if its a normal double flare, is it a metric thread? Since you're making your own lines that's OK, same line, just different nuts. But it'd be handy to have them when you leave the parts store.
Kudos on getting rid of rubber. I love knowing its all steel except for two little flex sections of a couple inches each.
And braided steel line is still rubber hose (which I have in a car, and probably should swap out soon).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-04-2014, 09:01 AM   #17
68shortfleet
Thanks, all
Pritch, when you do find the "right" one with 5/16" line and flare style fittings that we can work with, Could you please post up a part number???
68shortfleet is offline   Reply With Quote
Old 06-04-2014, 09:25 AM   #18
CATCHALLBLUE
CATCHALLBLUE's Avatar
Why do you say they are horrible? (Just put one in on my '69)
CATCHALLBLUE is offline   Reply With Quote
Old 06-05-2014, 11:13 PM   #19
pritch
pritch's Avatar
I'll do it, but I'm running into the dreaded metric thread thing someone mentioned
But I'm still looking.
'68 Panel
'68 C-10
Ol' Green
Old 06-06-2014, 02:59 PM   #20
davepl
davepl's Avatar
One crack and you've invented a gasoline sprinkler system underhood. And even at 7psi it'll hose things down with gas real good real quick. When will it stop? When you figure out what's going on and stop the engine from pumping fuel.
Some of them are plastic, so you get a grace period of a month or a year before they get brittle.
I'm not saying every one will explode and kill you, but the only time an OEM ever used a clear sight glass on fuel it was tempered glass and physically mounted in a safe place with no rubber lines and generally in a completely rigid assembly of some kind.
Steel's your friend. Heck, if it's a Q-jet just run the factory filter. It'll support 400hp at least. If it's a Holley or other, get something in all metal.
Old 06-06-2014, 03:28 PM   #21
hotrodder
yep on the glass filter being bad news. my cousin had one on a 48 ford coupe, it cracked and by the time he made it off the road and got the hood open it was up in flames. to each his own, but don't use these
hotrodder is offline   Reply With Quote
Old 06-06-2014, 10:09 PM   #22
CATCHALLBLUE
Great thanks for the advice guys. One more reason never to listen to the guys behind the counter of Advance Auto
Old 06-06-2014, 10:25 PM   #23
Codez67Chevy
Codez67Chevy's Avatar
That's a good idea for a filter. Looks exactly like the filter that I put in my Toyota truck. I could definitely make something like that work. Just get two bolts for the filter. Drill, bore, ream, and counter sink to size. Reflare the fuel lines and done! Definitely going to look into it. Great idea Pritch.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 06-06-2014, 10:31 PM   #24
Codez67Chevy
OK maybe I over thought this through. Lol ideas are flowing
Members I've met...
Mister-B
