Old 06-02-2014, 11:39 PM   #1
noahsmall
Truck just shuts off
I drive a 67' c10 with a 400sbc here recently I was going down the road and it started to sputter and jerk acting as if it was not getting enough gas. Pulled over sat for a few minutes and got it safely home. Turned it off. Started it back and it would shut off unless you keep giving it gas. I checked for vacuum leaks but there were none. Just wondering what the problem could be? Thanks for the help in advance.
noahsmall is offline   Reply With Quote
Old 06-02-2014, 11:48 PM   #2
sprint_9
sprint_9's Avatar
Re: Truck just shuts off
Checked fuel filter?
sprint_9 is offline   Reply With Quote
Old 06-02-2014, 11:50 PM   #3
noahsmall
I was going to change them out. It has two, not sure which one to change or to do both.
Old 06-03-2014, 10:01 AM   #4
BluTrukker
BOHICA
BluTrukker's Avatar
Try taking the gas cap off and starting it. There may be a vent issue with the tank that is creating a vacuum inside. Just happened to me with my lawnmower recently, some bug made a little home in the vent and it ran fine for a bit, but then wouldn't stay running without the choke
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 06-03-2014, 10:25 AM   #5
68gmsee
Active Member
68gmsee's Avatar
A few things to look at. Do easiest, cheapest first.
Fuel filters as mentioned above. If in doubt, replace both of them.
Again as mentioned above, if the cap has been replaced with a non venting one, that cold be the problem.
Ruptured fuel pump gasket. I had one that barely pumped gas and would die after a few minutes.
Junk inside the carb. Have to dismantle and clean it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-03-2014, 06:33 PM   #6
noahsmall
Thanks for all the replies! In the end I ended up changing both fuel filters and she runs like queen.
